Combustion Chamber Volume for a D15z1 vtec head??????
does any one know the Combustion Chamber Volume? What head can it be compared to so i can you the CR calcultor. Thanks for your help
http://www.knology.net/~jediklc/D.htm
Compression Calculator= if i use the D15B7 block (same CC sa Z1) with Z1 pistions (-7.05cc) with D15b7 head gasket, With the D16Y8 head i get 9.314314691544691 for a CR. Which is the same as a stock Z1 motor. So would it be fair to say the y8 head and the Z1 heads are the same volume??
hb_guy
Jan 16, 2006 07:31 AM
