anyone has a b7/z6 mini me??.......... i need help!!
after doing my b7/z6 mini me conversion i heard that there is a oil ristictor jet that has to be removed from the b7 block, is this true??
i have a metel head gasket.
can i reuse it??
can i reuse it??
B7 doesnt have a VTEC oil jet..... the oil jet its on the VTEC head......
and no u cant reuse the headgasket..... once they compress and provide seal they cant be reused......
the oil restriction jet in in the block if i am correct, and in order for vtec to activate, you must remove it. IMO, dont do a mini me, you end up with big holes in your block if you are running stock internals, and i have pictures to prove it
The A6,B2 block is plenty strong, so Mini-me's are mostly pretty solid. It's just from guys revving to 8k, thinking they're indestructible. Well, they're just like any other engine. Abuse em and they'll blow.
redline808
Apr 15, 2009 07:27 PM
92_VX_EG
May 12, 2007 06:31 AM
