93 Civ ECU location & cooling issues/main relay?
First off i tried to check the ECU for codes cause the civic is heating up. I replaced the stock thermo. w/ a OEM one. It was low on oil so I thought that this was the prob. But my sister says it still heats up. The fan works as well, comes on when it should. Could bubbles in the coolant cause this? Also where is the main relay @ and what are symptoms of it when its about to bite the dust?
tia
Blaze
tia
Blaze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 »</TD></TR><TR><TD CLASS="quote">First off i tried to check the ECU for codes cause the civic is heating up. I replaced the stock thermo. w/ a OEM one. It was low on oil so I thought that this was the prob. But my sister says it still heats up. The fan works as well, comes on when it should. Could bubbles in the coolant cause this? Also where is the main relay @ and what are symptoms of it when its about to bite the dust?
tia
Blaze</TD></TR></TABLE>
stock IS OEM....
drain coolant and add more...
tia
stock IS OEM....
