grind grind grind
Old Jun 28, 2001 | 04:11 AM
PatITR's Avatar
New User
Default grind grind grind
Wow I got my ITR almost 2 months ago and never grinded any of the gears at high speeds until last night, sheesh ever notice when you grind 1 time you get paranoid that you'll grind some more, well I grinded 3rd, then 2nd 3 times in a arrow, jeez did I feel ******* bad, how bad does grinding hurt the gears :\. O and what kind of seating do you guys have, very close the stearing wheel, I saw f&f and the guy practicly had his left foot jacked up to his belly, I may move my seat up. I wanna change my shiftnob, what's the best place to order it from on the net and which one is better. Any input would be appreciated thanks
Old Jun 28, 2001 | 04:22 AM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: grind grind grind (PatITR)
I know what you mean about grinding gears. I never used to do it, but once you do it a few times, you get scared, and it's like you can't stop. I've been grinding when I try to go from 2nd to 4th, or even 4th to 5th and 5th to 4th. Once your confidence in your shifting goes, you grind the **** out of it.
Old Jun 28, 2001 | 07:20 AM
PatITR's Avatar
New User
Default Re: grind grind grind (Ross1013)
That's all I got :\, btw is there a canadian site to order jdm parts such the shift **** and maybe a short throw stick(what are the advantages of having one of these, easier to shift?)
Old Jun 28, 2001 | 07:29 AM
2fcknfst's Avatar
Just learn how to double clutch and everything will be fine.
Old Jun 28, 2001 | 09:48 AM
ASNG's Avatar
New User
If you learn how to shift without using the clutch at all, basically matching revs and "unloading" the drivetrain with the right amount of throttle between shifts, rest assured, you will never grind when you actually use the clutch!
Actually the R shift pretty easily without the clutch. I mean I won't be doing a flat out run banging through the gears, but during a "casual" cruise it will shift no problem, you just need to be careful not to grind it!
00-0818 ITR PY
[Modified by ASNG, 1:49 PM 6/28/2001]
Old Jun 28, 2001 | 11:43 AM
ZygSpeed's Avatar
Default Re: grind grind grind (ASNG)
what's whith this crap, ... thought I had the signatures and images set as off!
Old Jun 28, 2001 | 11:48 AM
01r's Avatar
01r
New User
Default Re: grind grind grind (zygspeed)
hey ASNG that **** you have in your sig just made my ******* day!!!!!!!!!
BBBUUUUUWWWHHHAAAAAHHHHHAAAAAAAAAAAHHHAAAAAAAAAHHH HAAA
Old Jun 28, 2001 | 11:50 AM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
I grind the 1-2 every once in while. Usually I can tell if I've missed the shift and stop before grinding it, but every so often....oops. It shouldn't be too bad if you don't end up forcing it and let go as soon as you hear the noise.
I've done it on the 4-5 shift just cruising on the freeway once too, that was weird. I think I took to long to shift or something, it just didn't feel right. Like the engine and trany were spinning at different speeds and the synchros didn't work right.
Old Jun 28, 2001 | 12:01 PM
Type Goch's Avatar
New User
Default Re: grind grind grind (newt2)
grinding 1-2 is rare, but slightly grinding 2-3 at high revs is sometimes hard to avoid.
twentyhurtz
Jan 16, 2009 11:19 AM
90teg91hatch
Jun 2, 2008 06:49 PM
cmy-vtec
Dec 29, 2004 05:10 PM
Kellindal
Aug 28, 2001 08:31 AM
MintyDip
Aug 23, 2001 07:02 AM
