Are these lowering springs any good???
Old Apr 19, 2003 | 05:19 PM
allicedout's Avatar
Default Are these lowering springs any good???
I bought my 91 civic and they came with "MATRIX" adjustable coilovers. I've never heard of them before. Are they any good or just sum cheap set like ractive or APC. If anyone knows let me know. (The ride sucks)
Old Apr 19, 2003 | 05:22 PM
sleeperb's Avatar
Default Re: Are these lowering springs any good??? (allicedout)
matrix=cheap. but I personally have never experienced any coilovers that had a good ride.
Old Apr 19, 2003 | 05:34 PM
CRXSi90's Avatar
Default Re: Are these lowering springs any good??? (sleeperb)
yeah, they're cheaper ones, but you might not be much better off with anything else. Basically, coilovers are about two things, spring rate and quality of the perch/sleeve. Unless you know what you want, the spring rate is probably fine for you. Also, unless you are having problems with the perch sticking or anything, or want an easier thing to adjust, you are probably fine with this too.
Coilovers are generally harsher than springs, so this may play a part of the harsh ride, but your shocks may be bad which will give you a different harshness. You might have heard this before, but you probably need new shocks. Since you have coilovers which you can adjust, you might want to look into '87-'89 (?) shocks to increase your travel. This would be especially helpful if you want to be really low.
Old Apr 20, 2003 | 04:24 AM
allicedout's Avatar
Default Re: Are these lowering springs any good??? (CRXSi90)
Thanks for your help. Basically you guys have said what i was thinking. I've never had coilovers before and personally do not like the ride. I'm gonna go back to what I know and replace these coilvers with a set of H&R racing springs.
civic01coupe
Honda Civic (2001 - 2005)
Mar 7, 2008 02:34 PM
sohcvtec97
Feb 25, 2005 07:07 AM
Turbo-GSR1287
Feb 3, 2005 04:31 PM
03ephatch
May 20, 2004 10:13 PM
Civicta
Aug 3, 2003 11:39 AM
