alxe nut problem ...
Old Apr 19, 2003 | 04:00 PM
respectblades's Avatar
Default alxe nut problem ...
ok trying to crack the axle nut....
i have a breaker bar... and a pole on the the bar for leverage
my friends pushing the brake to stop the rotor from turning...
and it turns ...
should i bleed the brakes or is this something else...
i'm in the middle of a swap and don't have time for stupid **** to slow me down
Old Apr 19, 2003 | 05:13 PM
sackdz's Avatar
Default Re: alxe nut problem ... (respectblades)
You could put the wheel on and on the groud then break it. Also yea I'd say either the brakes need to be bled or your friend is a *****.
Old Apr 19, 2003 | 06:36 PM
SoulDigger's Avatar
This is the way I always got my axle nuts off without the need of anyone's help. You need to put a beefy screwdriver in one of the slots of the rotor then spin it until it locks on the caliper stopping it from spinning and enabling you to remove the axle nut.
Old Apr 19, 2003 | 07:50 PM
b19coupe's Avatar
Default Re: alxe nut problem ... (SoulDigger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoulDigger &raquo;</TD></TR><TR><TD CLASS="quote">This is the way I always got my axle nuts off without the need of anyone's help. You need to put a beefy screwdriver in one of the slots of the rotor then spin it until it locks on the caliper stopping it from spinning and enabling you to remove the axle nut. </TD></TR></TABLE>
Or an impact gun, my weapon of choice.
Old Apr 19, 2003 | 08:11 PM
Lord Helmet's Avatar
yeah, thats what I always do.
Old Apr 19, 2003 | 08:29 PM
SCsol's Avatar
Default Re: alxe nut problem ... (sleeperciv)
put it on the ground!!! If you break the breaker bar, get a 24" pipe wrench gride off the sides of the socket just so the pipe wrench has someting to grab onto and put a bar on it for leverage. If that dont work your fucked!!!
Old Apr 19, 2003 | 09:57 PM
krazyDOHC's Avatar
Default Re: alxe nut problem ... (SCsol)
yea...slap the wheels back on and put it on the ground......so both you and your friend can try and break the nut loose...
btw took us 2 ppl and a long *** breaker bar to break that **** loose
Old Apr 19, 2003 | 10:00 PM
MikeMAN's Avatar
Default Re: alxe nut problem ... (krazySOHC)
on my buddy's car it was easy, it came off itself! *imagine the consequences!
Old Apr 25, 2003 | 10:10 AM
Default Re: alxe nut problem ... (MikeMAN)
the zc in and the axle nuts can kiss my ***
swaps been done for to day now
Sketch_hs
29
Mar 31, 2017 10:35 PM
Skipper75
21
May 5, 2007 10:51 PM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
RCautoworks
48
Nov 27, 2006 12:26 AM
respectblades
12
Apr 25, 2003 02:31 PM
