code 8
Old Apr 19, 2003 | 03:55 PM
daniel89civ's Avatar
Default code 8 how can i fix it
iam getting code 8 tdc how to fix
the engine is zc dohc swaped 20 day ago it just started to throw code 8
Old Apr 19, 2003 | 05:47 PM
scratchline20's Avatar
Default Re: code 8 how can i fix it (daniel89civ)
Your timing is probably off. When #1 cylinder is at top dead center(tdc), the cam gears should both be pointing up, slightly inward. If they aren't correct them. If they are, check your ignition timing and test the sensor. I don't know exactly how to test the sensor. I know there is a website with the entire manual for the edm CRX Si(ZC) and CRX Vti. I just don't remember where. If anyone knows, please post it.
ef_zc
Aug 12, 2008 06:04 PM
saccord
Nov 21, 2005 07:24 PM
done
Oct 8, 2002 03:37 PM
EF'n
Aug 20, 2002 01:11 PM
