Time to see what oil you using, yeah another poll.
Old Apr 19, 2003 | 02:13 PM
Bbasso's Avatar
Default Time to see what oil you using, yeah another poll.
Its been a while since the last poll for motor oils.
Lets see what is the top choice still...
I only am able to put in the 9 choices, but if you use something that is not on the list please add it in. But to those who add something else- Beware-
I do not work for a oil company, just want to find out what all of you use
I would like to know the amount of oil you burn per 1000 miles of street use too.
Old Apr 19, 2003 | 02:21 PM
CPR's Avatar
CPR
Default Re: Time to see what oil you using, yeah another poll. (Bbasso)
I'm still using Mobil1 since I'm too brainwashed to change.
EDIT - I burn .3333333333333333333333333333333333333333333333333 33333333333333333333333333333... quarts per 1000 miles
Old Apr 19, 2003 | 02:22 PM
Joker's Avatar
Default Re: Time to see what oil you using, yeah another poll. (CPR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">I'm still using Mobil1</TD></TR></TABLE>
Ditto
Old Apr 19, 2003 | 02:29 PM
Bbasso's Avatar
I'm using Mobil 1 5-30 and I burn about a quart per 1000 miles if driven hard.
But when I do a HPDE sesson I can burn a quart alone
Modified by Bbasso at 1:15 AM 4/20/2003
Old Apr 19, 2003 | 02:49 PM
magic hat #9's Avatar
pennzoil 5w30 in winter
pennzoil 10w30 high mileage in summer - moly!
i burn 1-1.25qt every 3333miles which is better than the 1.5-2qts with mobil 1.
Old Apr 19, 2003 | 02:50 PM
rated_r's Avatar
Default Re: Time to see what oil you using, yeah another poll. (magic hat #9)
Vavoline 10W30 All Climate
Old Apr 19, 2003 | 03:14 PM
Vampyre's Avatar
Default Re: Time to see what oil you using, yeah another poll. (rated_r)
and mobil puls ahead
Old Apr 19, 2003 | 04:30 PM
1GreyTeg's Avatar
Agip 10W60... Changed it before the Expo, drove 400 or so miles then ragged on the car for 2 days, then drove back another 400 or so miles and I just checked it today,,, didn't go down a bit...
A.
Old Apr 19, 2003 | 04:34 PM
oz#227's Avatar
New User
Mobil 1 0w-40 Tri synth. Since 10,000 KMS. Now at 62,000 kms.
My car doesn't use any oil between oil changes ( every 10,000 kms) unless i'm at the track. Then it uses about 100Mls ( about a mouth full ).
But I believe my lack of oil use ( even using this thin oil, which is both over and under spec's) is due to my run-in method. IE:- Don't listen to what the manufacture tells you about run-in. Their method just help them get more money out of us.
Later.
Old Apr 19, 2003 | 04:57 PM
Flux's Avatar
Default Re: Time to see what oil you using, yeah another poll. (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Agip 10W60... </TD></TR></TABLE>
Where the hell are you getting Agip oil?
Old Apr 19, 2003 | 05:01 PM
1GreyTeg's Avatar
Default Re: Time to see what oil you using, yeah another poll. (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
Where the hell are you getting Agip oil? </TD></TR></TABLE>
Direct fro Agip of course,,, why doesn't everybody?
If you are interested in it I will send you the phone numbers... But, it's gotta be Tuesday when I get back to work since they are there and I am elsewhere.
A.
Old Apr 19, 2003 | 05:53 PM
VTHokie's Avatar
Still using regular oil, car only has 6000 miles on it Planning on making the switch to mobil 1 10w30 soon
Old Apr 19, 2003 | 07:30 PM
Chris93Si's Avatar
Mobil 1 forever!
Hmmm maybe .333-.500 quarts/1000 miles, burn baby burn
Old Apr 19, 2003 | 08:16 PM
BDiddy's Avatar
Default Re: Time to see what oil you using, yeah another poll. (Chris93Si)
Honda 10W30
About 1 quart every 3000 miles. Decided I didnt like buring money away with the Mobil 1 oil.
Old Apr 19, 2003 | 08:19 PM
io_burn's Avatar
New User
Default Re: Time to see what oil you using, yeah another poll. (BDiddy)
Castrol GTX 10w30, about 1000 miles on it so far and I haven't burnt a drop as of yesterday
Old Apr 19, 2003 | 08:45 PM
2000 Integra R #760's Avatar
Default Re: Time to see what oil you using, yeah another poll. (io_burn)
Redline
Old Apr 19, 2003 | 09:05 PM
Bob#455's Avatar
Chevron 5W-30...I burned less than 1 qt. after 2 hours of HARD track time yesterday.
Old Apr 19, 2003 | 09:30 PM
Kengs's Avatar
Default Re: Time to see what oil you using, yeah another poll. (Bob#455)
Shell Rotella 5W40 synthetic
Old Apr 19, 2003 | 10:07 PM
98type_r's Avatar
New User
Default Re: Time to see what oil you using, yeah another poll. (kengs)
GTX 5w30
Old Apr 19, 2003 | 10:39 PM
NZITR's Avatar
Default Re: Time to see what oil you using, yeah another poll. (tie par)
Motul 300V Power Racing 5W30
Only been in a month but seems fine so far.. only issue was the price
Old Apr 19, 2003 | 11:03 PM
ITR1330's Avatar
mobil 1 10W30, but i dont have permission to vote
Old Apr 19, 2003 | 11:43 PM
zentraedityper's Avatar
NEO 5w30.. only the best!
nEoMuGen's Avatar
Default Re: (ITR1330)
Redline 10-30w...hardly burns 1/2 quart every 3,000 miles.
Old Apr 20, 2003 | 12:21 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: (nEoMuGen)
Mobil 1 costs too much. Castrol ownz all. Nothing burned since the new block went in
Old Apr 20, 2003 | 12:32 AM
TypeR 599's Avatar
Default Re: (RealTypeR)
castrol is pull mobil in
