Removing crankshaft pulley
Old Jun 28, 2001 | 12:28 AM
raene's Avatar
Default Removing crankshaft pulley
Is the easiest way to remove the crankshaft pulley (for a timing belt change) to remove the transmission and then wedge a bolt into the flywheel teeth? 'Cause that seems like an awful lot of work... is there an easier way to do this on a B16A or a D16A6?
Old Jun 28, 2001 | 03:47 AM
Big James's Avatar
New User
Default Re: Removing crankshaft pulley (raeneshadow)
The easiest way is to get a tool to do it properly. They sell a tool that goes in the crank pulley to hold it in place while you insert your socket through it.
Old Jun 28, 2001 | 06:33 AM
clockworks's Avatar
The best way is to get a hold of a good impact wrench. You can take it to a shop and have them break torque on it if it's been on there a few years and frozen, then retighten it a bit below spec so you can drive home. Then just wrench it off.
Greg
Old Jun 28, 2001 | 03:01 PM
raene's Avatar
Default Re: Removing crankshaft pulley (Big James)
Big James: Who sells a 'tool'? I've heard of them but never seen them... I'd certainly love to get one! I thought it was only for the B18C, though...
clockworks: I actually reinstalled it myself a while back, so it shouldn't be frozen... think I could break it loose myself if I just put the tranny in gear and use a big extension?
Old Jun 28, 2001 | 07:40 PM
Gasoline Fumes's Avatar
Put it in 5th gear and have someone step on the brake pedal. With a long pipe on a breaker bar, it should come off. I've done this after an impact wrench wouldn't loosen it.
Old Jun 28, 2001 | 07:54 PM
blaze's Avatar
Default Re: Removing crankshaft pulley (Gasoline Fumes)
i use a chain wrench that i got from snap-on a long time ago to hold the pulley in place...
Old Jun 28, 2001 | 07:58 PM
raene's Avatar
Excellent advice guys . Thanks, I appreciate it!
Old Jun 29, 2001 | 01:58 PM
accordking's Avatar
Moroso has the tool you're looking for.. Even though a tool truck will have it readily available.. That's where I got mine SNAP ON all the way!!! Come to think about it I need to trade in my tool box for a bigger one....
[Modified by accordking, 2:58 PM 6/29/2001]
Old Apr 14, 2004 | 07:08 PM
B16CRXT's Avatar
Default Re: Removing crankshaft pulley (blaze)
Would autoZone rent out the chain wrench? How would I use it?
My timing got messed up yesterday while I was going down the highway and the belt skipped a few teeth
EDIT: I searched for these tools and it seems to me that they all would require a second person.
Chain wrench (I really dont see how this could work)
http://buy1.snapon.com/catalog...talog
Crankshaft pulley wrench: looks ok, but I think I would bust my hand up using this thing?
http://www.moroso.com/catalog/...27115
Old Apr 14, 2004 | 07:19 PM
mmuller's Avatar
Mad Scientist
Default Re: Removing crankshaft pulley (B16CRXT)
i take the flywheel cover out and wedge a big screwdriver there, it works everytime.
you can also do it through the starter hole
Old Apr 14, 2004 | 07:40 PM
LudeyKrus's Avatar
Use an impact wrench.
Air tools come in handy in so many different situations, I don't see how anyone could NOT justify the cost!
Old Apr 14, 2004 | 07:53 PM
mmuller's Avatar
Mad Scientist
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Use an impact wrench.
Air tools come in handy in so many different situations, I don't see how anyone could NOT justify the cost!</TD></TR></TABLE>
yeah...but an impact wrench dont work all the time unless you have like a 800 pound one...
and a lot of people want a more economical way than buying a compressor and an impact gun....
not everybody floats in money
Old Apr 14, 2004 | 08:01 PM
LudeyKrus's Avatar
Default Re: (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">
not everybody floats in money</TD></TR></TABLE>
I have an IR 231 gun w/ 425 ft/lb's that has been through my entire car and 4 motors and it hasn't hit a bolt it couldn't bust yet!
And i'm the epitome of a broke college kid, but I scrapped up $350 for the compressor w/ tool set and IR gun, and have saved that much in blood and time. I've actually made most of my money back from various side-jobs for people.
Back to the original topic!
Old Apr 14, 2004 | 08:11 PM
mmuller's Avatar
Mad Scientist
so lets state the obvious:
Best choice with less time, bla, bla
1)impact gun(over 300ft/lb's, cause i have a 250ft/lb one and it does not work most of the time)
2)crank pulley holder tool:
3)screw driver in flywheel
4)putting the car in 5th(not sure that works good since the car will still rock and makes it hard to concentrate the strenght)
5)
Dutch_commando
11
Jun 24, 2017 08:26 AM
budomove
Nov 2, 2007 07:26 AM
hu
Apr 15, 2007 07:34 PM
Perogi
Dec 22, 2005 07:26 PM
94vtecmn
Apr 21, 2003 12:08 PM
