crappy d16 dyno day, lol
Old Apr 19, 2003 | 01:29 PM
skhonda's Avatar
Default crappy d16 dyno day, lol
My setup:
stock d16y8
t3/t4 .50 trim, .48 ar
6.5 psi
370cc injectors
v-afc
hks FMIC
Greddy evo catback, with 2.5" test pipe
Act HDSS clutch
stock ignition, stock timing
currently untuned, the dyno shop just opened up and will not have a wideband 02 sensor until they raise some money and buy one. I'm running really rich and my hp is really pathetic.
And the vid of my second dyno pull, crazy BOV action going on.
http://www.we-todd-did-racing....3D%3D
Overall, unimpressive and disappointing.
Old Apr 19, 2003 | 01:35 PM
omahaturbocivic's Avatar
Default Re: crappy d16 dyno day, lol (skhonda)
Is the dyno shop in Ia too? If so who is it and where at?
Old Apr 19, 2003 | 01:42 PM
skhonda's Avatar
Default Re: crappy d16 dyno day, lol (omahaturbocivic)
The dyno is at 1455 S 1st Ave. in Iowa City, 53340 (319-354-7503)
They are called Overdrive Performance.
Apparently they have a dyno shootout the 25-27 from 10am - 4pm both days. $20 entry free, get a dyno run, graph, and a t-shirt.
I'll probably head down there to hang out for a bit on the 26th, but definitely not embarass myself on the dyno again. That day i'm heading to Cedar Falls to embarass myself at the track.
Old Apr 19, 2003 | 02:00 PM
M.A.R.C.'s Avatar
yah man ur car needs like it needs some tuning. at 5-6psi on my T3 i was making 165whp/140tq on the stock cat so you'e not THAT bad. I'm switching to a similar turbo as you but the 46 trim... gnna redyno at 6psi and see if my numbers go up.
Old Apr 19, 2003 | 02:01 PM
JRSCCivic98's Avatar
From the looks of the dyno plot you're running lean everywhere from 3600 on up. Your HP shouldn't die off like that. And depending on the smoothing setting for the plot it looks like you're missing a lot up there also. If you think you're running rich because you're seeing black smoke comming out of the exhaust pipe don't be fooled. I had black smoke too (puffs) when I walked on the dyno. I was lean up top too. When I put the a/f ratio back up to about 12 my HP started climbing and was a lot smother then it was on the first run. 153 is kinds weak for 6.5 even from a D16Y8. You should be able to get another 30 hp from proper a/f ratio.
Old Apr 19, 2003 | 02:57 PM
M.A.R.C.'s Avatar
Default Re: crappy d16 dyno day, lol (JRSCCivic98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRSCCivic98 &raquo;</TD></TR><TR><TD CLASS="quote">From the looks of the dyno plot you're running lean everywhere from 3600 on up. Your HP shouldn't die off like that. And depending on the smoothing setting for the plot it looks like you're missing a lot up there also. If you think you're running rich because you're seeing black smoke comming out of the exhaust pipe don't be fooled. I had black smoke too (puffs) when I walked on the dyno. I was lean up top too. When I put the a/f ratio back up to about 12 my HP started climbing and was a lot smother then it was on the first run. 153 is kinds weak for 6.5 even from a D16Y8. You should be able to get another 30 hp from proper a/f ratio.</TD></TR></TABLE>
i was thinking that too... i remmeber hearing from someone that a jagged dyno line like that is like missing/detonation or something to that effect.
skhonda: what kinda bov is that? i likes it a lot... getting tired of my rabid parakeet type-s
Old Apr 19, 2003 | 07:44 PM
skhonda's Avatar
Default Re: crappy d16 dyno day, lol (CivicRyda2k)
The bov is max-rev's custom one.
S@nt0s
Jun 19, 2006 07:48 PM
KOALA YUMMIES
Jul 16, 2005 04:01 PM
M.A.R.C.
Mar 9, 2003 03:28 PM
Project X
Jun 19, 2002 01:15 PM
