Need help deciding which Civic radiator to get.
My car is overheating; I'm buying a radiator next. Which one should I get?
I hear the PWR one has fitment problems on the 00 Civic.
I don't know how good the quality of each radiator compares with each other, especially C&R. I've only heard that PWR is better than Fluidyne, so how does C&R compare with the other two?
Thanks,
Mike
Thanks,
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nine »</TD></TR><TR><TD CLASS="quote">Get a del sol dual core w/ fal fans.</TD></TR></TABLE>
I kinda need AC. And I don't want to hear anything about AC's for wusses; it's for the ladies!
Everything fits the 00 civic OK , For the budget set up the 95 Del sol dual core . I would go with a Koyo or a C+R with a Spal fan , Then look at a lower temp thermostat. You should be OK then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral »</TD></TR><TR><TD CLASS="quote">I like my PWR and FAL
I was looking at a PWR for my D16Y8.
Did you have any fitment issues with the PWR? I know they are made for the B-series.. What radiator hoses did you use?
Thanks
Eric
</TD></TR></TABLE>I was looking at a PWR for my D16Y8.
Thanks
Eric
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midwestrider »</TD></TR><TR><TD CLASS="quote">
Thanks
Eric</TD></TR></TABLE>
He told me he used GSR hoses and had to trim the brackets for the FAL fan a little.
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSi »</TD></TR><TR><TD CLASS="quote">get a del sol dual core or 99-00 si radiator. It works fine.</TD></TR></TABLE> Is it a direct drop in for the del sol core in a 92 CX HB with a b16? My old stock radiator has a tiny hole on top where it is mounted. [IMG][/IMG]
pwr works great for me..........fitment is not a prob. it fits great......you can also bolt the stock fan onto it if it fits in your bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote"> Then look at a lower temp thermostat. You should be OK then.
I bought the Mugen 170 deg t-stat. In the winter when I was n/a my car couldn't get warm enought to get out of open loop.
I still have it if anyone wants it.
[edit] i have the lower temp fan switch too. From inline-4
I went with a PWR radiator. I will probably buy a thin fan from Auto Zone or something along those lines. I have not installed it yet (waiting for the new block to be put in, head work and other stuff to get finished).
http://photos.yahoo.com/bc/alp...o.com/
We run a c&r in our race car and i they are the best quality of the three. You can also get them with a spal fan already mounted on aluminum rails welded to the radiator. That's the way to go...
All these big fat *** radiators are overkill for most people. If my LS turbo engine ran cool in Texas on a stock single core, a dual core should be more than enough for an SOHC.
But hey, if you've got money to burn, burn it! That's why they make those giant radiators
JMinSi2000
Jan 7, 2005 10:44 AM
