help with removing lower dash
anyone have any pics or instructions on removing the under dash kick panels and center console area - i want to do it right and not snap and break any parts off. thanks
steps to removing the center console.....
1-remove the little plastic piece from underneath your e-brake handle , remove those 2 bolts .
2-on the sides of the armrest piece there are 2 screws , one on each side , remove those . now the arm rest piece should come out .
3-on to the piece that connects to the dash . the front of this piece has 2 screws , one on each side , take those out .
4-now remove your ash tray . look inside there and there should be 3 screws back there , take them out . now that hole ashtray/lighter section should be able to come out.
5-now that the ashtray section is removed you will see 2 screws towards the top where you just removed that last piece , take those out .
that should be all the screws you need to take out to remove the center console
Junkyard2000
Nov 8, 2005 11:50 AM
