bent rod??
I think you might have spun a rod bearing. Just to be on the safe side, I'd suggest you drop the oil pan and check the rod bearings. It'll only cost you five quarts of oil and about 2hours out of your time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHB »</TD></TR><TR><TD CLASS="quote">I think you might have spun a rod bearing. Just to be on the safe side, I'd suggest you drop the oil pan and check the rod bearings. It'll only cost you five quarts of oil and about 2hours out of your time.</TD></TR></TABLE>
i already did that..I thought a bearing made a kind of rattle in a can sound..I 've heard spun bearings before and this doesn't sound like that..
If you bend a rod, the motor will probably not turn over and it sure won't make power. A spun bearing will sound like a hammer hitting inside and you will lose lots of oil pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">If you bend a rod, the motor will probably not turn over and it sure won't make power. A spun bearing will sound like a hammer hitting inside and you will lose lots of oil pressure.</TD></TR></TABLE>
If the motor was loosing oil pressure then it still wouldn't be making good power.??
D16Y8-JDMYO
Oct 22, 2006 04:02 PM
boostedeghatch
15
Mar 2, 2005 12:55 PM
Unsivil_audio
Jan 19, 2005 11:23 AM
