Will a stock p72 with no modifications run h22?
Old Apr 19, 2003 | 10:35 AM
MindEracer's Avatar
Default Will a stock p72 with no modifications run h22?
I was wondering if a p72 with no modifications will run a h22a?
I know handata uses chiped p72's to drive h22's, but can it do it with no mods.
I've done some searching and found this site http://www.importreview.com/re....html , they have a comparison of an h22a using a p72 and a p13.
The p72 produced higher top end power!!!
From what I've gathered the p13 is very differtent from other obd1 ecu's.
So I'm wondering if anybody has tried this and if you had any problems (CEL's, blown ecu's etc.)
Old Apr 19, 2003 | 10:42 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: Will a stock p72 with no modifications run h22? (LudeType-T)
it will run it, but it will run lean
Old Apr 19, 2003 | 10:55 AM
MindEracer's Avatar
Default Re: Will a stock p72 with no modifications run h22? (Boosted97Lude)
So, is there any other problems that will arise!!
Could I use the the Uber turbo chip and tune it to work for an h22a w/ no major problems!!
Old Apr 19, 2003 | 01:12 PM
Russ713's Avatar
dAng!
yes, you can chip a p72 for a h22 setup. That's what mike (Lildrgn) did for his hondata setup.
HAccord96
Oct 10, 2007 09:49 AM
kholmes
Mar 12, 2005 06:23 AM
AzNpRiD3
May 17, 2004 02:46 PM
1.8T_EG
May 6, 2003 09:20 AM
ArchAngel Sabastian
Nov 26, 2002 03:40 PM
