Noise Suppressing Plug Wires?
Old Apr 18, 2003 | 06:49 PM
Regular Series's Avatar
Default Noise Suppressing Plug Wires?
Does such a thing exist? I just heard from a co-worker today that there are spark plug wires that are better at keeping ignition noise out of your audio system. Does anyone have any more information? TIA
Old Apr 18, 2003 | 07:58 PM
t0p_sh0tta's Avatar
Default Re: Noise Suppressing Plug Wires? (Risingson)
I've seen them around, but I couldn't tell you where to find them. What's the point? I would assume that a ground loop isolator, or improving grounds and other connections will yield better results. The latter would also be much cheaper.
Old Apr 18, 2003 | 08:21 PM
Default Re: Noise Suppressing Plug Wires? (t0p_sh0tta)
Well, I'm going to try re-grounding my power amp first. The speaker wires could probably also stand to be moved. I just figured I'd find out about noise suppressing cables while I was at it~
Old Apr 18, 2003 | 09:44 PM
TurboBumblBee's Avatar
just get a good set of monster cable rca wires and you should not have any problems with anything..
Old Apr 19, 2003 | 12:49 AM
vteg's Avatar
New User
Are you currently getting interference? The magnacores are supposed to provide good rfi suppresion. The stock wires should not have noise. The noise is normally in aftermarket wires. If you have stock wires I would not mess with it unless it is time to replace them anyway.
The magnecores are supposed to outlast your vehicle. I have 50k on mine and counting
Old Apr 19, 2003 | 08:51 AM
Default Re: Noise Suppressing Plug Wires? (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX &raquo;</TD></TR><TR><TD CLASS="quote">just get a good set of monster cable rca wires and you should not have any problems with anything..</TD></TR></TABLE>
Oh, I'm well beyond Monster....
I'm getting some noise from right front speaker (not sure if the rear is getting it). I have cheap-*** Belden plug wires in there now (long story), so that's why I'm exploring this avenue.
Old Apr 19, 2003 | 11:28 AM
vteg's Avatar
New User
I have not tried monster cable lately. I always had bad luck with them in cars.
Old Apr 19, 2003 | 11:49 AM
Default Re: Noise Suppressing Plug Wires? (vteg)
My experience with Monster is that they have weak solder joints and make the sound thick and fuzzy. The AudioQuests I'm using are somewhat sensitive to noise, but they're also nowhere near my power lines.
Old Apr 20, 2003 | 05:44 AM
rjr162's Avatar
as for the plug wires... The non-resistor wire/plug setup will make more engine noise than the resistor wires/plugs. (ok well I could have left the plug part out.. it's the wire really)
Old Apr 20, 2003 | 05:50 AM
Default Re: Noise Suppressing Plug Wires? (rjr162)
OK...so the Magnecors are non-resistors?
Old Apr 20, 2003 | 11:31 AM
vteg's Avatar
New User
Magnecore are not resistor. They use spiral wound wire to prevent RFI. Basically it is supposed to be a race wire that will not mess up your radio.
Old Apr 20, 2003 | 02:32 PM
Hm...any idea on prices?
Old Apr 20, 2003 | 11:02 PM
vteg's Avatar
New User
For a 4 cylinder honda around $90.
Old Apr 21, 2003 | 02:26 PM
I'll try my other options first....
tegasaurus
Mar 5, 2004 06:53 AM
Littleredsi
12
Dec 13, 2003 05:49 PM
zcivicz
Audio / Security / Video
Nov 23, 2003 08:48 PM
blk97lude
Jul 31, 2003 04:14 AM
