How often should..
Old Jun 27, 2001 | 06:25 PM
MaxPowerIntegra's Avatar
Default How often should..
How often should a valve adjustment be done? if i advance my intake camshaft, would i then have to adjust my valves? TIA
Old Jun 27, 2001 | 07:22 PM
gsr camel's Avatar
Default Re: How often should.. (IntegraPoweR)
look in yo manual it will list the maintenance scheule
(i know the spelling is off)
Old Jun 27, 2001 | 08:13 PM
Erik_Pb_Foot's Avatar
New User
Default Re: How often should.. (gsr camel)
there's a post on here somewhere... guys @ 40k and getting it done.. I"m at 100k and getting it done... i think it has to be done every so often... if you hear your valves, it's definatly time!
Old Jun 27, 2001 | 10:56 PM
blaze's Avatar
Default Re: How often should.. (Pb_Foot)
if you can do the valve adjustments yourself, do it whenever you start hearing them tick loud... especially if you hit redline alot.
Old Jun 28, 2001 | 05:39 AM
keithv's Avatar
The manual says to do it every 30k. I suggest learning how to do it yourself and then you can check them as often as you'd like!
At 30k, I adjusted about half of my valves on the intake and exhaust side. I redline often and auto-x the car, so its seen its share of the rev limiter.
HTH.
Old Jun 28, 2001 | 05:48 AM
E Swift's Avatar
Default Re: How often should.. (breaka_1_9)
If you redline at almost all lights, I was told to have them adjusted every 6000 miles if you have a Vtec eqipped car.
Old Jun 28, 2001 | 06:41 AM
mattymatt's Avatar
New User
So did you buy an valve adjusting tool? Or did you do it without one...
Old Jun 28, 2001 | 06:48 AM
blaze's Avatar
Default Re: How often should.. (mattymatt)
valve adjustment tool comes in handy and speeds up the work, but you can still perform a valve adjustment without if your low on funds. it is a good investment though for only around $40-$50 if i remember correctly
Old Jun 28, 2001 | 10:24 AM
Phat Corolla's Avatar
New User
Default Re: How often should.. (blaze)
so where do we get a "how-to" on valve adjustment? would it be in the CHILTON manual?? I'll have to look when i get home.
Old Jun 28, 2001 | 10:27 AM
blaze's Avatar
Default Re: How often should.. (Phat GS-R)
i'm not sure if chilton's has it but a helm's manual will. i'm not sure, but i think you can also check the c-speed site..
Old Jun 28, 2001 | 10:30 AM
keithv's Avatar
Since I am bored at work, here is the link to the c-speedracing site:
http://www.c-speedracing.com/howto/v...lveadjust.html
Old Jun 28, 2001 | 02:15 PM
thanx guys, but my question was if i had to adjust my valves after advancing/retarding my cam sprockets..
Old Jun 28, 2001 | 02:23 PM
blaze's Avatar
dang, we went way off topic didn't we. you don't have to adjust your valves
Old Jun 28, 2001 | 05:53 PM
EminemGSR's Avatar
When was the last time you got them adjusted?
If you hear a "tapping" in your engine after or before advancing/retarding cam sprokets you would need to get them adjusted. Also, the more often you drive in VTEC, the more likely you'll need to get them adjusted sooner than what your owner's manual suggests.
Old Jun 28, 2001 | 05:59 PM
slowerthanu's Avatar
New User
Default Re: How often should.. (EminemGSR)
alot of the audible ticking is also related to your injectors opening and closing. I adjust mine every 5-8000 miles but I also race quite often
Old Jun 29, 2001 | 02:00 PM
Default Re: How often should.. (slowerthanu)
thanx fellas..thats why this site is so dope...
Old Jun 29, 2001 | 02:45 PM
JL 74's Avatar
The manual says inspect at 30k miles.
I took my car to the dealer (Hopkins Acura). They asked me if I hear tapping noise, I said "NO". He listened to my car and then told me to go away. Well, not go away but to come back when I hear tapping noise or reach 60k miles. From what the guy said, yeah, they can look at my valves and "inspect" its clearances (after they let it sit for a few hours until it cools) but he won't be adjusting anything and will take my $135. These guys are good.
Yellow Submarine
Jul 20, 2014 06:49 AM
lordbucanero
Sep 11, 2012 05:51 PM
85_305
21
Jan 12, 2009 01:51 PM
Tenacious T
Honda Motorcycles
May 26, 2007 10:35 AM
jdm169
Jan 24, 2003 05:36 PM
