Injector help dsm 450cc on obd2 civic
Old Apr 18, 2003 | 06:12 AM
Carlito Brigante's Avatar
Default Injector help dsm 450cc on obd2 civic
Hey fellas first off before i get one ripped i did search...
Im currently rebuilding my 00 Si. i crashed it and decided to just go all out on it one more time. the price of getting the front end fixed and repainted well 1700...
here is what i have
drag manifold
tial wastegate. 45bar
drap dp
drag turbo
aem ems
im running low on funds as i have still to buy a intercooler, charge pipes well u know.
im trying to cut some ends. will dsm 450cc injectors work on my obd2 civic? i know they worked on the crx i did however thats obd0 and it has a resistor box. what do i have to do to use them on the Si..
Will the aem be able to pulse them or am i gonna need resistors on the wires?
any help would be great..
Old Apr 18, 2003 | 06:30 AM
MikeMAN's Avatar
Default Re: Injector help dsm 450cc on obd2 civic (em1-t)
yes you need resistors, and 10watt 10ohm will work well. You can get these from radio shack for cheap.
hope that helps,
mike
Old Apr 18, 2003 | 01:05 PM
Default Re: Injector help dsm 450cc on obd2 civic (MikeMAN)
hrm. thats it just one per each correct so imma need 4?
any links to this?>
Old Apr 18, 2003 | 01:11 PM
turbod16y8's Avatar
correct... this will help u out ....http://www.homemadeturbo.com/tech_pr...ors/index.html
Old Apr 18, 2003 | 04:58 PM
turbosol's Avatar
Default Re: Injector help dsm 450cc on obd2 civic (turbod16y8)
Just buy a used honda resistor box, you can splice it into the engine harness under the intake manifold. There is a plug under the manifold that has a cap on it and all of the injector power wires go there. It's real convenient. The EG's have the same plug but it is in front of the clutch resivoir.
Civiclx
May 11, 2007 08:36 AM
1baddcivicsi
Aug 3, 2006 11:23 AM
Louis53123
Jan 2, 2006 10:06 PM
B18C5civic
Oct 23, 2005 09:26 AM
BLACKLUDE97
Dec 24, 2003 04:25 AM
