can i use my cx o2 sensor on my b16
Old Apr 18, 2003 | 05:44 AM
roc's Avatar
roc
Default can i use my cx o2 sensor on my b16
just curious cause,i'm using my cx harness,and the 02 plugs r stiil unconnected to an 02,so i figure that i can just swap the cx 02 onto the b16 without doing any wiring.would this work
Old Apr 18, 2003 | 08:05 AM
KENetics1's Avatar
Default Re: can i use my cx o2 sensor on my b16 (roc)
No because your ecu for the b16 is made for a 4wire 02 sensor and the cx 02 sensor is a 5 wire. In other words if you do that the ecu will throw a cel.
Old Apr 18, 2003 | 10:10 AM
Katman's Avatar
Default Re: can i use my cx o2 sensor on my b16 (KENetics1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENetics1 &raquo;</TD></TR><TR><TD CLASS="quote">cx 02 sensor is a 5 wire.</TD></TR></TABLE>
Wrong.
A CX 02 sensor is single wired.
(yes ecu w/throw check engine light if you use a CX 02 on B16A and B16A ecu)
A VX 02 is the 5-wire'd 02 sensor.
Old Apr 19, 2003 | 01:05 PM
roc's Avatar
roc
i will be using a chipped p28 ecu,so it should be fine.right
Old Apr 19, 2003 | 01:38 PM
globlctzn's Avatar
Default Re: (roc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roc &raquo;</TD></TR><TR><TD CLASS="quote">i will be using a chipped p28 ecu,so it should be fine.right</TD></TR></TABLE>
did a p28 come with a cx? no
you need a 4 wire o2 for a p28 ecu, you might be able to use one from a d16z6 (what the p28 was made for).
Old Apr 19, 2003 | 03:09 PM
dfoxengr's Avatar
Default Re: (globlctzn)
wont work.
u can get a 4wire from almost any honda except CX and VX
Old Apr 21, 2003 | 10:32 AM
Katman's Avatar
Default Re: (hybridvteceg)
yep..
you can use virtually any 4-wire OBD1 or OBD2 02 from any non-vtec or SOHC/DOHC VTEC engine(s).
SHG_EasyE
Jan 21, 2006 03:23 AM
droppedeg6hatch
22
Dec 12, 2005 12:50 PM
kun3racer
Jan 23, 2004 05:59 PM
