City light help
Old Apr 17, 2003 | 09:46 PM
Denny's Avatar
Default City light help
I know this topic has been covered before, but i couldnt find the answer through search. I wasnt sure if it should be in apperience or what but would think it would be better here.
Is this light the daytime running light, if so its supposed to be on when the headlights are off? and it turns off when you click light to parking light correct? if not daytime running light, what is it? thanks
Old Apr 17, 2003 | 09:49 PM
canuck-mx6's Avatar
Default Re: City light help (TypeR882)
It is the park light, the turn signals are single filament bulbs, not dual like the turn signals on the USDM integra. The city lights are the JDM version of the park lights
Old Apr 17, 2003 | 09:50 PM
Denny's Avatar
Default Re: City light help (canuck-mx6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canuck-mx6 &raquo;</TD></TR><TR><TD CLASS="quote">It is the park light, the turn signals are single filament bulbs, not dual like the turn signals on the USDM integra. The city lights are the JDM version of the park lights</TD></TR></TABLE>
so when is it supposed to be on?
Old Apr 17, 2003 | 09:54 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR882 &raquo;</TD></TR><TR><TD CLASS="quote">
so when is it supposed to be on?</TD></TR></TABLE>
Whenever USDM parking lights would be on (i.e. when the parking or head lamps are switched on).
canuck-mx6's Avatar
When the park lights are on, and when the headlights are on. If you are really ****, you can use a socket that takes a dual filament bulb (1157) and wire up the turn signals to be the park lights as well
Old Apr 17, 2003 | 09:57 PM
tC_Dragon's Avatar
it supposedly should turn on with the first click/turn of ur light combo switch.
Old Apr 17, 2003 | 10:04 PM
Denny's Avatar
Default Re: City light help (pdcdragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdcdragon &raquo;</TD></TR><TR><TD CLASS="quote">it supposedly should turn on with the first click/turn of ur light combo switch.</TD></TR></TABLE>
does it turn off after the second click when u turn your low beams on?
Old Apr 17, 2003 | 10:08 PM
Padawan's Avatar
Darth ModerVader
Default Re: City light help (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Whenever USDM parking lights would be on (i.e. when the parking or head lamps are switched on).</TD></TR></TABLE>
This is really as simple as the concept can be made.
Old Apr 17, 2003 | 10:35 PM
tC_Dragon's Avatar
does it turn off after the second click when u turn your low beams on?</TD></TR></TABLE>
no it does not
Old Apr 17, 2003 | 10:38 PM
Denny's Avatar
thanks
Old Apr 17, 2003 | 10:51 PM
MiraiZ's Avatar
they are curtousey lamps (aka city lights)...they are used in Japan when stopped at a stoplight. People usually turn their headlights off so not to blind the person in front of them.
Old Apr 17, 2003 | 11:14 PM
lePetitePrince's Avatar
Default Re: City light help (MiraiZ)
mine is one when my low beam is on, how can I make it turn off when i have my low beam on?? I only want it as my daytime running light, but don't want it when my HID goes on, what can i do?
Old Apr 17, 2003 | 11:26 PM
MiraiZ's Avatar
Default Re: City light help (lePetitePrince)
you will need to have a separat switch for the city lights or rig the current switch with a secondary switch for the citylights...
Old Apr 18, 2003 | 01:26 AM
:jdmshmaydm:'s Avatar
So after the first click when turning on your lights, only the city lights should be on? then when you turn on the headlights everything is on?
Old Apr 18, 2003 | 04:03 AM
HiRevn's Avatar
Default Re: City light help (Gatecrasher19AF)
When you turn your parking lights on, they're on, when you click one more time and your headlights are on, they're still gonna be on. It's that simple.
Old Apr 18, 2003 | 07:27 AM
Padawan's Avatar
Darth ModerVader
One more time for the record. When the headlight switch is in the off position, all lights will be off (no DRL's). When turned to the first click (parking light), the tail lights and the city lights will be on. Also on this click, if the foglamps are switched on, they too will be illuminated. On the second click (headlight) the city lights, tail lights, and headlights will all be on. Again, if the foglamps are switched on, they will illuminate on this click as well. As for the corner lenses and sidemarkers, they will only illuminate if the hazards or the turn signals are used. Some individuals may choose to wire the city light to a daytime running light (DRL) source, and others may choose to use a dual-filament bulb in the corner lenses to function as both a parking light and a turn signal, but the above description is how the factory JDM lights would operate.
Chris - who never thought this would be so hard to understand.
Old Apr 18, 2003 | 08:28 AM
Ideal R's Avatar
New User
One stupid question:
Is high beam bulb the light bulb slightly above the parking light?
Thanks!
Old Apr 18, 2003 | 08:49 AM
Padawan's Avatar
Darth ModerVader
Default Re: City light help (Ideal R)
Yes, in the photo at the top, the high-beam bulb is the one above and to the left of the city light.
invader_zim
Mar 28, 2012 09:57 PM
Nuttynutnut
Honda Civic (2001 - 2005)
18
Apr 6, 2008 05:24 PM
DC2Header
Nov 28, 2005 04:44 AM
DOHC_C-REX
15
Oct 5, 2005 10:01 AM
