Will a 215/45-16 azenis fit the teg?
Will a 215/45-16 azenis fit the teg? It might be tight but there aren't very many sticky tires for 16's. I would go with 15's but I think they look a little small on 4 door tegs.
Modified by sfr4dr at 4:29 AM 4/18/2003
Your question is hella unclear. Are you trying to make a statement? Or determine wether 215/45/16 Azenis will fit on 16 or 15" rim?
If you want to get azenis and have a 16" rim. 215/45/16 is the correct size you need.
Yeah, I just want to know if it will fit. I know the azenis is a little wider than most tires of the same size and the 215 is also wider than the recommended 205 width.
I debated a long time whether to go 15 or 16's with azenis. I didnt want to end up rubbing so i went with 15s. I found out later 16s will fit provided you have the right offset and arent dropped ridiculously with bad camber. +40 offset 7" wide rims should clear without fender rolling. hth
sibicguy
Sep 25, 2003 02:22 PM
