what would be the AN equivalent to replacing the lower radiator hose?
Old Apr 17, 2003 | 04:00 PM
civbeater90's Avatar
Default what would be the AN equivalent to replacing the lower radiator hose?
for all you guys with hardcore setups what size braided do you run for rad hoses?
is it something close to like a -22AN?
Old Apr 17, 2003 | 04:07 PM
TREVER's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (civbeater90)
-20
Old Apr 17, 2003 | 06:23 PM
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (TREVER)
anyone else?
Old Apr 17, 2003 | 06:46 PM
SEFIxCivic's Avatar
i've been told -16 is the size to go.
Old Apr 17, 2003 | 07:43 PM
tony1's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (SEFI8LOxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFI8LOxCivic &raquo;</TD></TR><TR><TD CLASS="quote">i've been told -16 is the size to go.</TD></TR></TABLE>
I've done a bunch of setups with -16 and haven't had any problems with any of them. -16 is a little smaller than stock, but it doesn't hurt.
Old Apr 17, 2003 | 08:45 PM
blufke's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (tony1)
how do you keep the ends from fraying? is there some special fitting that will just get slid over and clamped down?
Old Apr 17, 2003 | 09:47 PM
XDEep's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (blufke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke &raquo;</TD></TR><TR><TD CLASS="quote">how do you keep the ends from fraying? is there some special fitting that will just get slid over and clamped down?</TD></TR></TABLE>
there are different procedures for different fittings.. you can just use masking tape and saw/dremel it for a clean end.
is there a formula for finding the AN? i have some charts around here somewhere..
Old Apr 17, 2003 | 10:45 PM
blufke's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (XDEep)
an is whatever the number is(i.e. -22 AN) over 16. so 22/16".
Old Apr 18, 2003 | 05:28 AM
BoostedH23a1's Avatar
how the hell u attach it to the radiator... do one of these sleeve tricks then flare it?
Old Apr 18, 2003 | 05:47 AM
tony1's Avatar
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (BoostedH23a1)
The correct way to do it is weld male an fittings on the radiator and water necks from the motor. You're not going to be able to stretch one over you radiator. Stainless line is designed to be used with the proper fittings. If you want a cheap way out then get the greddy hoses.
Old Apr 18, 2003 | 08:11 AM
VTECPWR's Avatar
"an is whatever the number is(i.e. -22 AN) over 16. so 22/16"."
Need to add that AN is the OD not in ID.
Old Apr 18, 2003 | 04:23 PM
Default Re: what would be the AN equivalent to replacing the lower radiator hose? (VTECPWR)
u mean heliarched....
Old Apr 18, 2003 | 05:54 PM
im thinking more along the lines of -18 or even -20
Old Apr 18, 2003 | 06:10 PM
SEFIxCivic's Avatar
listen to tony, he knows what hes talking about. if you've never seen a -20 in person, i'll tell you... its freakin huge.
Old Apr 19, 2003 | 09:52 AM
dude i already have -16 -18 and -20 fitings sitting in my garage,i know how big they are.im just trying to keep the ID about the same.oh and by the way i never doubted tony so relax.jus looking for diffrent opinions is all.
rolin rotas
Jul 30, 2009 08:32 AM
g2turbo
Oct 9, 2006 12:06 PM
Turbocivic94
Mar 20, 2006 05:33 AM
speedworks
Dec 11, 2005 03:14 PM
Jared
Dec 4, 2004 06:19 AM
