what would be the AN equivalent to replacing the lower radiator hose?
for all you guys with hardcore setups what size braided do you run for rad hoses?
is it something close to like a -22AN?
Re: what would be the AN equivalent to replacing the lower radiator hose? (SEFI8LOxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFI8LOxCivic »</TD></TR><TR><TD CLASS="quote">i've been told -16 is the size to go.</TD></TR></TABLE>
I've done a bunch of setups with -16 and haven't had any problems with any of them. -16 is a little smaller than stock, but it doesn't hurt.
Re: what would be the AN equivalent to replacing the lower radiator hose? (tony1)
how do you keep the ends from fraying? is there some special fitting that will just get slid over and clamped down?
Re: what would be the AN equivalent to replacing the lower radiator hose? (blufke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blufke »</TD></TR><TR><TD CLASS="quote">how do you keep the ends from fraying? is there some special fitting that will just get slid over and clamped down?</TD></TR></TABLE>
there are different procedures for different fittings.. you can just use masking tape and saw/dremel it for a clean end.
is there a formula for finding the AN? i have some charts around here somewhere..
how the hell u attach it to the radiator... do one of these sleeve tricks then flare it?
Re: what would be the AN equivalent to replacing the lower radiator hose? (BoostedH23a1)
The correct way to do it is weld male an fittings on the radiator and water necks from the motor. You're not going to be able to stretch one over you radiator. Stainless line is designed to be used with the proper fittings. If you want a cheap way out then get the greddy hoses.
"an is whatever the number is(i.e. -22 AN) over 16. so 22/16"."
Need to add that AN is the OD not in ID.
im thinking more along the lines of -18 or even -20
Re: what would be the AN equivalent to replacing the lower radiator hose? (civbeater90)
listen to tony, he knows what hes talking about. if you've never seen a -20 in person, i'll tell you... its freakin huge.
dude i already have -16 -18 and -20 fitings sitting in my garage,i know how big they are.im just trying to keep the ID about the same.oh and by the way i never doubted tony so relax.jus looking for diffrent opinions is all.
