compression prob
Old Apr 17, 2003 | 03:10 PM
94civicexlsvtec's Avatar
Default compression prob
i have a prob the #1,2,4 cyl have 270 the number 3 has 150 what do you think it is how can i fix it?
thanks
Old Apr 17, 2003 | 03:32 PM
Chiovnidca's Avatar
Default Re: compression prob (94civicexlsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicexlsvtec &raquo;</TD></TR><TR><TD CLASS="quote">i have a prob the #1,2,4 cyl have 270 the number 3 has 150 what do you think it is how can i fix it?
thanks</TD></TR></TABLE>
Do a leakdown test to narrow down the problem before you take it apart.
Old Apr 17, 2003 | 03:33 PM
Default Re: compression prob (TurboD16Chiovnidca)
whats a leak down test?
Old Apr 17, 2003 | 04:35 PM
slomofo's Avatar
GDD Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicexlsvtec &raquo;</TD></TR><TR><TD CLASS="quote">whats a leak down test?</TD></TR></TABLE>
Do your leakdown test by applying 100 psi of air into the cylinder while the cylinder is on it's compression stroke at TDC, make sure all your spark plugs are removed. While the air is in the combustion chamber do the following steps:
1. Remove radiator cap and look for bubbles, if you see bubbles then your headgasket is bad.
2. Put your ear next to the cylinders on each side of the one you're testing, if you hear air seeping through then your head gasket is bad.
3. Remove air filter, if you hear air, then you have either a sticky intake valve or broken valve spring.
4. Put ear near exhaust pipe, if you hear air then it's sticky exhaust valve or broken valve spring.
5. Remove oil cap, if you hear air, then you have bad piston rings.
Edit: I haven't done a leakdown test in many many years, so if I missed something, then feel free to correct me.
Old Apr 17, 2003 | 07:12 PM
Default Re: compression prob (slomofo)
ok found out what it was.....bad rings no how bad would it be if i keep driving the car? say for 3-4 days also how do i know what rings to buy they were already in the block when i bought it built by dh racing..what would have made the rings go bad? and last can i just replace the bad rings or do i need to replace them all?
Old Apr 17, 2003 | 09:06 PM
ScottEK's Avatar
Awsome explanation of the leak down test, I've always wondered what it was also. Is there a way to replace rings without taking the block out of the car?
Old Apr 18, 2003 | 01:40 AM
Stripped Honda's Avatar
99-0104
Default Re: compression prob (beta13)
yesyou can but i wouldnt mess with doing it just yank it out and rebiuld it the right way
Old Apr 18, 2003 | 03:17 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicexlsvtec &raquo;</TD></TR><TR><TD CLASS="quote">ok found out what it was.....bad rings </TD></TR></TABLE>
How do you know it's not a bad piston?
Old Apr 18, 2003 | 06:30 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">... 5. Remove oil cap, if you hear air, then you have bad piston rings.
Edit: I haven't done a leakdown test in many many years, so if I missed something, then feel free to correct me.</TD></TR></TABLE>
How about this... If you hear it from your oil cap, it could also be a bad piston.
Old Apr 18, 2003 | 09:54 PM
NismoNX's Avatar
Default Re: compression prob (JimBlake)
It was the piston. Will have a new one in the morning.
Old Apr 19, 2003 | 10:29 AM
Chiovnidca's Avatar
Default Re: compression prob (NismoNX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NismoNX &raquo;</TD></TR><TR><TD CLASS="quote">It was the piston. Will have a new one in the morning.</TD></TR></TABLE>
What happened to it?
Old Apr 19, 2003 | 01:01 PM
the ring land broke into like 4 pieces i think it was detionaon(btw i cannot spell) anyway im in the process of installin a new one right now. that are pr3 piston which ones whould be best to put in if this happens agin?
Old Apr 20, 2003 | 08:35 AM
NismoNX's Avatar
detionaon.....thats some funny ****!!!!!!!!
Old Apr 20, 2003 | 10:36 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NismoNX &raquo;</TD></TR><TR><TD CLASS="quote">detionaon.....thats some funny ****!!!!!!!!</TD></TR></TABLE>
I think he means detonation.
Old Apr 20, 2003 | 04:39 PM
NismoNX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboD16Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
I think he means detonation. </TD></TR></TABLE>
I know he's a friend of mine, and I am always giving him hell about how he can't spell.
Fat Chick Magnet
Sep 28, 2006 06:24 PM
Chubz
Honda S2000
20
May 1, 2006 10:37 AM
joostan
Nov 29, 2005 07:01 AM
tweekerz
Apr 30, 2004 09:43 AM
hatch4raceb16
Nov 29, 2003 01:50 PM
