dohc on crx???
Old Jun 27, 2001 | 11:49 AM
RICEBURNER1406's Avatar
New User
Default dohc on crx???
could someone out there tell me of i can put a 90-93 integ dohc on my crx si? what else would i need to do? plaese lemme know!!! what i mean is just the head and cams, nothing else
[Modified by RICEBURNER1406, 9:44 PM 6/27/2001]
Old Jun 27, 2001 | 12:06 PM
stockcrix1616's Avatar
Default Re: dohc on crx??? (RICEBURNER1406)
youll need the ecu from the teg, and place racing or ha sport will have kits to bolt it in i think,
Old Jun 27, 2001 | 01:19 PM
crux131's Avatar
Default Re: dohc on crx??? (stockcrix1616)
No dude he means something similar to a mini-me set up using the head off of the Integra d-series engine.
I don't know if that can be done though. You could probably get teh head gasket for each car and compare them, that would give you some clue.
Old Jun 27, 2001 | 03:13 PM
JG Luder's Avatar
Default Re: dohc on crx??? (crux131)
Or just ask Don... AKA obd1canobie... he might tell you, he might not.
Old Jun 28, 2001 | 04:52 AM
eg6ajk's Avatar
Default Re: dohc on crx??? (JG Luder)
b-series and d-series DOHC heads are not interchangble or bolt on to any d-series SOHC blocks...its almost impossible....unless you got $$$$$$ then its okay.....
just get a ZC they are dirt cheap and enjoy a factory DOHC, with same HPs and little less torque but whole alot of reliabilty....
Old Jun 28, 2001 | 06:19 AM
Default Re: dohc on crx??? (eg6ajk)
you can, seen it done, how i have no clue, but he did it at his own shop,
Old Jun 29, 2001 | 11:03 PM
Coleon's Avatar
Are you familiar with ZC's. Im trying to find some forged rods for mine. Can you Help? John
Old Jun 30, 2001 | 06:48 AM
rioninja's Avatar
No you CANT. The B18a engine has a different bore, and is much wider than your si engine. No B-series (most integra) engine components are compatible with D-series (most civic)
Old Jun 30, 2001 | 08:26 AM
New User
Default Re: dohc on crx??? (RioNinja)
thanks alot rioninja, its all i wanted to know!!!!
Old Jul 1, 2001 | 06:42 AM
CRX_VTEC's Avatar
Actually it CAN be done. My brothers Sohc block got a Doch swap on to it..I'm not sure what modification had to be done to the block, but its simular to the ZC. I know it was alot work and he wouldnt have done it if it wer under normal circumstances. But he does alot of swaps and people just tend to give away their old engines afterwards and he just took all those mix and match of blocks and heads and made a running motor with it.
91DroppedHatch
18
Jan 19, 2005 01:53 PM
damn_import_culture
Dec 31, 2004 11:58 PM
illogic65
42
Nov 1, 2004 10:01 AM
street dreams
15
Oct 10, 2004 05:46 PM
Hulkbuster
Feb 8, 2003 11:08 AM
