HELP HELP! 4th Gen Lude Code 43
Old Apr 17, 2003 | 01:13 PM
92-h23a1's Avatar
Default HELP HELP! 4th Gen Lude Code 43
CEL code 43 - Fuel Supply System
Everything is stock, except for AEM intake. What could be the problem?
Old Apr 17, 2003 | 01:27 PM
poison's Avatar
Default Re: HELP HELP! 4th Gen Lude Code 43 (92-h23a1)
When did you install the intake?
Reset your ECU and see if that works.
Old Apr 17, 2003 | 01:37 PM
92-h23a1's Avatar
Default Re: HELP HELP! 4th Gen Lude Code 43 (poison)
I already reset the ECU, its been in there for while already.
Old Apr 17, 2003 | 01:38 PM
poison's Avatar
Car start at all?
Old Apr 17, 2003 | 02:30 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92-h23a1 &raquo;</TD></TR><TR><TD CLASS="quote">CEL code 43 - Fuel Supply System
Any running problems? If the fuel presure stays in spec, it's usually a bad o2 sensor.
Old Apr 17, 2003 | 06:52 PM
92-h23a1's Avatar
Default Re: HELP HELP! 4th Gen Lude Code 43 (TurboD16Chiovnidca)
Well It runs fine on 1-4th gear. when i hit the highway on 5th the light comes on it stays on till i come to a stop and park. when i try to turn it back on it'll just sound like its trying but won't spark. i cheecked the code, it came up as 43. after like 5 minutes it'll start again. ?
Old Apr 18, 2003 | 06:37 AM
BoM's Avatar
BoM
i[
Old Apr 19, 2003 | 01:17 PM
92-h23a1's Avatar
Default Re: HELP HELP! 4th Gen Lude Code 43 (BoM)
bump
J.nguyen
May 20, 2006 12:37 AM
Saltine Box Racer
Mar 7, 2004 07:56 PM
92-h23a1
May 15, 2003 04:21 AM
92-h23a1
Apr 18, 2003 06:38 AM
