JDM itr header, cat, and exhaust fit?
So there would be not cutting or welding of any sort right? And would the it be able to pass smog or would the CEL go on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Ls4dr »</TD></TR><TR><TD CLASS="quote">would the it be able to pass smog or would the CEL go on?</TD></TR></TABLE>
As long as everything is bolted up correctly (o2 sensors included) there is no reason for the CEL to go on, and it should pass smog, although that could be effected by what you've done to the motor.
oh ok, that sounds good. I was just hesitant of getting it because i didn't know if the JDM cat would our emissions. Thanks for the replies guys
I'm reasonably sure that the JDM ITR cat. doesn't have an 02 bung. If installed on a 4-door, the B-pipe length will need to be modified as well.
Oh really? Because i picked up a 4 door jdm exhaust and i was planning just to the header and cat if it just bolted right on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Ls4dr »</TD></TR><TR><TD CLASS="quote">Oh really? Because i picked up a 4 door jdm exhaust and i was planning just to the header and cat if it just bolted right on. </TD></TR></TABLE>
Ah. I didn't see any reference to the ITR exhaust being from a 4-door, so I assumed you meant the more common 2(3?) door version. The length should be fine then, but I'm still relatively sure that the cat. will have no 02 bung, just the smaller cat. temp sensor bung.
Oh so the CEL will still go on huh. So i should just get a carsound cat and the JDM itr header. Thanks for your help padawan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Ls4dr »</TD></TR><TR><TD CLASS="quote">Oh so the CEL will still go on huh. So i should just get a carsound cat and the JDM itr header. Thanks for your help padawan</TD></TR></TABLE>
You will also realize a greater performance benefit by using a quality aftermarket high-flow cat. instead of the factory JDM ITR cat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I'm reasonably sure that the JDM ITR cat. doesn't have an 02 bung. If installed on a 4-door, the B-pipe length will need to be modified as well. </TD></TR></TABLE> nah the cat does come w/ an 02 bung even came w/ the sensor, unfortunately it was a 1 wire sensor. but i did get it on after extending the bpipe about 8 inches, 02 sensor not plugged in and no CELs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 »</TD></TR><TR><TD CLASS="quote"> nah the cat does come w/ an 02 bung even came w/ the sensor, unfortunately it was a 1 wire sensor.</TD></TR></TABLE>
I think you're referring to the cat. temp sensor.
Also, if his car is a '96 as his username suggests, he will indeed have a CEL if there is no secondary 02 after the cat.
wakaranai
Jan 22, 2009 11:27 PM
TypeRP2
May 28, 2004 10:56 AM
