Kenji P28 Emissions test =p
Old Apr 17, 2003 | 10:00 AM
Nameless RB26's Avatar
Default Kenji P28 Emissions test =p
Did a little emissions test today for fun with my Kenji chipped P28 on the JDM ITR engine.
Cat is gutted as well..
2000 rpm
430 HC
3.87 CO
12.5 CO2
14 O2
163 NOx
13 A/F
IDLE
6.63 HC
6.61 CO
10.6 CO2
0.4 O2
70 NOx
11.9 NOx
Runs rich no doubt. Everything else is horrible just as expected without a cat.
I think I need new plugs as well.
Just an FYI for anyone who cares..
Old Apr 17, 2003 | 10:03 AM
JDM CTR '00's Avatar
Default Re: Kenji P28 Emissions test =p (Nameless EJ6)
That's what CA Emissions should be like lol maybe even worse
Old Apr 17, 2003 | 11:15 AM
kenji's Avatar
25 Year Member
Default Re: Kenji P28 Emissions test =p (ChargedSi99)
My ECUs really shouldn't be used for emissions testing (if you want to pass). Chances are any race program out there (including mine) will fail an emissions test miserably.
However, I did have one customer with a Del Sol that passed emissions using my ECU. Don't know how he passed but he did pass.
-kenji
Old Apr 17, 2003 | 11:16 AM
splitime's Avatar
Default Re: Kenji P28 Emissions test =p (kenji)
Heh, crap, looks like I may need to find a virgin p28 towards the end of the summer. Bloody yearly emissions testing.... Damn you Kenji for making my car more fun to drive!
Old Apr 17, 2003 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kenji &raquo;</TD></TR><TR><TD CLASS="quote">My ECUs really shouldn't be used for emissions testing (if you want to pass). </TD></TR></TABLE>
I knew it wouldn't pass... this was just for fun. It's a goot ecu though..
Old Apr 17, 2003 | 01:12 PM
wantmorepower's Avatar
New User
Thank you So much for sending me the new chip for Free (since I am so **** about my car running rich)----I installed the new chip last night and It works.
I don't know the specs of the chip you sent me (is it open or close loop? and when does vtec comes on) I would really like to know. Thank you again.
Old Apr 17, 2003 | 04:33 PM
Default Re: Kenji P28 Emissions test =p (wantmorepower)
Kenji - if you come back to this thread.. can you tell me more about the chip this dude is talking about? I'd like to know if there is an alternative to running the "richer" chip all the time.
The one I'm using I believe is causing my 02 sensor code to pop on every now and then. I could try some new plugs too though..
Old Apr 17, 2003 | 07:30 PM
gamby's Avatar
Hmmm. Interesting. I have to get my car smogged soon, and I'm feeling too lazy to zero out my camgears, reset my timing and swap out ECU's. I think I'm going to try smogging it for the helluvit. I'll just lean everything out to high heavens on the V-AFC...
Old Apr 18, 2003 | 03:32 PM
Spunkster's Avatar
On my car, i failed with stock injectors, stock ecu, and wired bypass valve open with cat in place. But i passed the obd2 scan check, so i put in the p72 with hondata and 440 c injectors and let the bypass valve operate normally...passed with little more than a fart (aka hardly any emissions)
Old Apr 18, 2003 | 07:00 PM
MK Ultra's Avatar
Default Re: Kenji P28 Emissions test =p (Spunkster)
Yup.
A friend of mine is a Hondata dealer. His car can pass emissions (in my state at least) without a cat.
Old Apr 19, 2003 | 06:07 PM
VTHokie's Avatar
Default Re: Kenji P28 Emissions test =p (MK Ultra)
Thank god i have inside connections! Fock da environment!
video_voide
Engine Management and Tuning
Feb 6, 2013 12:17 PM
NoVALude
May 25, 2006 04:42 PM
one slow eg5
12
Oct 9, 2004 07:35 PM
b18sol
Apr 27, 2003 09:54 PM
