Front brake swap on an EK
Old Apr 17, 2003 | 08:01 AM
1BlackHatch's Avatar
Default Front brake swap on an EK
I know this has been asked before but I have found a lot of conflicting information. I would like someone to state definitively the answers to these questions.
1) Will 94-01 Integra Front knuckles and brake assemblies work on a 2000 DX hatch?
2) Is there any difference in the geometry of these parts?
3) Will there be any issues with the brake lines?
4) Are there any other ramifications of this that I am not aware of?
Thank you.
Old Apr 17, 2003 | 08:04 AM
Takeoff's Avatar
Default Re: Front brake swap on an EK (1BlackHatch)
1. It will work.
2. There is slight difference but very small and nothing to worry about.
3. Just use you civic lines but they will need to bent slight unless you get some si lines.
4. Hopefully you don't get bad parts. When I did mine I didn't realize I got a bad spindle so I had to replace and spend more money.
Old Apr 17, 2003 | 08:15 AM
Default Re: Front brake swap on an EK (Takeoff)
Thanks for the quick response. Just one more question.
Did this affect your camber in any way?
Old Apr 17, 2003 | 10:00 AM
ttt
Old Apr 17, 2003 | 10:08 AM
psi420's Avatar
Everything should work fine, and your camber should not be affected.
Old Apr 17, 2003 | 10:40 AM
Default Re: (psi420)
Excellent. Thanks to all.
Old Apr 17, 2003 | 09:14 PM
Ok. I need to ask one more question. Will 90-93 GSR front brakes work on my car?
Old Apr 18, 2003 | 03:49 AM
bump
Old Apr 18, 2003 | 05:48 AM
up
Old Apr 18, 2003 | 09:42 AM
Does anyone know the answer to this?
Old Apr 18, 2003 | 10:05 AM
Katman's Avatar
My turn...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">
-- YES ... but you HAVE to use your DX upper A-arms. The DC upper A-arms are NOT the same as EK a-arms. Simply transfer them over to the DC knukkaz.
-- To my knowledge, no. Camber/caster all that shouldn't be affected, I mean of course, you'll have to get an alignment just to reset everything, but you can still go on the same specs as your EK camber/caster/etc...
-- For the fronts No. You can either reuse your DX lines or go with the GSR lines, its up to you.
-- yes, I GOT MAIL......YAAAAAAAAAY!!!
Thank you.</TD></TR></TABLE>
5) NO, you cannot use DA knukkaz & hub assembly on a EK......that geometry is way off/different. You can only use EK, EG, 94-00 DC knuckkaz/hub assy on an EK.
Old Apr 18, 2003 | 10:22 AM
Default Re: Front brake swap on an EK (Katman)
Thanks.
Old Apr 18, 2003 | 10:23 AM
Katman's Avatar
yep.
dck1ng69
Jan 1, 2018 12:57 PM
wamo575
Jun 15, 2010 05:33 AM
KillerBee18
Mar 22, 2005 08:02 PM
Richard Noggin
29
Dec 22, 2003 12:37 PM
Incubus05
Nov 10, 2003 08:23 PM
