How to break in Hawk Blue pads?
Old Jun 27, 2001 | 07:00 AM
White Dragon's Avatar
Default How to break in Hawk Blue pads?
What is the recommended way of breaking in the Hawk Blue pads?
Old Jun 27, 2001 | 07:10 AM
Yell00ITR's Avatar
Default Re: How to break in Hawk Blue pads? (White Dragon)
Generally, the best way to bed pads is to take your car out after installing them on a safe, uncrowded street and do several (about 5 or 6) stops from 30mph to 0 holding the brake pedal firmly (Not slamming it, just firmly). This will warm up the pads enough to start the outgassing process (IE: You should smell/see some smoke from the brakes). Now, take it up to 60mph and do the same thing..about 4 or 5 stops from 60 to 0 while holding the brake firmly. That is it, you are done. Well, actually, you arent done. What you want to do after this is drive for about 10-20 minutes on a highway or something (with little braking) to give the pads a chance to cool down. After that, your are done. Go inside and have a
This procedure should work for all pads (particularly race pads), but hawk might recommend a slightly different break in procedure.
[Modified by Yell00ITR, 8:11 AM 6/27/2001]
Old Jun 27, 2001 | 07:36 AM
2fcknfst's Avatar
Default Re: How to break in Hawk Blue pads? (Yell00ITR)
Go into an alley.
Drive forward to about 25mph, gently apply brakes and stop.
Reverse down the same alley to about 25mph, apply brakes gently stop.
Repeat procedure 6 or 7 times. Park car do not drive for 1/2 hour.
After that, brake away.
Old Jun 27, 2001 | 07:37 AM
Chris's Avatar
Here you go!
https://honda-tech.com/zerothread?id=44956
Old Jun 27, 2001 | 12:27 PM
Default Re: How to break in Hawk Blue pads? (Chris)
Thanks for all of the help guys
Arsenal
Nov 30, 2006 12:50 PM
B18c5__Owns
Mar 24, 2006 01:08 PM
Gen5lude
Apr 1, 2003 01:04 PM
