Tein problem Need help quick
Old Apr 16, 2003 | 11:50 AM
asmallsol's Avatar
Default Tein problem Need help quick
Alright, I put my ITR Tein HA's on my sol today (using ITR rear control arms) and I have a major problem with the rear. I got the front on all good but the back are haveing problems. There is no way to tighten them. From where the top of the rear strut tower ends to the begging of the thread, there is a good 3 inches. It is so un drivable because every time I hit a bump (even small) my rear springs doesn't compress, the car just bounces real bad. I bough a box of washers to try and take away from the gappage but it still is bouncing as hell and they make tons of noise. Please help quick
Old Apr 16, 2003 | 11:51 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Tein problem Need help quick (asmallsol)
lol you are missing some hardware. Steel washer(s) to be exact.
Ryan
Old Apr 16, 2003 | 11:55 AM
splitime's Avatar
****, dont ride on that anymore like that! Right on the shaft of the shock by the bushings you should see that the rod is slightly larger, there should be a washer that goes onto the shock first, below the bushings, then another washer on top of the bushings and then you bolt it down.
Old Apr 16, 2003 | 11:56 AM
shinestreetwill's Avatar
New User
Default Re: Tein problem Need help quick (vtecvoodoo)
Double chech the instructions again. You are missing a steel washer at the top that you need to use off your stock suspension set up
Old Apr 16, 2003 | 11:59 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: Tein problem Need help quick (shinestreetwill)
Old Apr 16, 2003 | 12:44 PM
Brewer's Avatar
Yeah it looks like you're missing #'s 1 and 16 in the pic, and obviously #12 (or is it 2?) which is why the shaft is so far up. I did the same thing when I installed some GC's a couple years ago...
Old Apr 16, 2003 | 01:00 PM
asmallsol's Avatar
Default Re: Tein problem Need help quick (BrewerHatch)
Thanks, I finally solved it after reading some of your posts.
vtecvoodoo, Since I am not using pillow ball mounts, what side should I put the rubber mounts on, top or bottom?
Old Apr 16, 2003 | 01:02 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
one on top and bottom of that hat.
asmallsol's Avatar
alright thanks
Old Apr 16, 2003 | 01:14 PM
asmallsol's Avatar
Voodoo, if you put them on both sides, there is not enough bolt to screw the whole thing back together
So krazieY
Honda Civic (2006 - 2015)
Jun 20, 2010 09:23 PM
JDMslowboy
Jul 14, 2009 01:59 PM
pli
Suspension & Brakes
Jun 5, 2008 04:52 PM
mikey1829
Honda Civic (2001 - 2005)
Mar 25, 2008 09:27 PM
jansenrw
Sep 21, 2003 06:59 PM
