Aftermarket Tach (1992 Civic Hatch CX)
I could be wrong... BUT
check the firewall right in front of the driver side, behind the shock tower. Look for ablue wire, with blue tape on it. This wire is the signal for the tach.
As for the 12v lighting power, tap into your dimmer switch by the steering wheel or the port on the fusebox
For the 12v ignition, you can either turn to the fusebox again, or right to the ignition.
Ground is a nice clean unpainted part of the body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 »</TD></TR><TR><TD CLASS="quote">I could be wrong... BUT
right on the money man
thanks
here is a pic I just made. The fat white wire is for your 12v+ lights, and the red is for your 12v+ ignition... Just slap a female spade connector on the end of the wire, crimp it down, and plug it in! honda rules.
90crxdriver
10
Nov 4, 2006 12:14 PM
Tippyman
Apr 22, 2006 04:05 PM
BlueIntegraBoy
May 13, 2005 05:45 PM
racekar
Apr 30, 2004 03:04 PM
