Which Flywheel to use???
Old Apr 16, 2003 | 10:07 AM
hybridnorth's Avatar
Default Which Flywheel to use???
im looking to get a different flywheel
i chewed up my stock one using a cm stage 4
what im looking for is something stronger than stock, but i really want is the one with the re-change able surface, which i believe is the cm one.
right now its narrowed down to ACT Streetlite which weighs 12.5lbs and their PROLITE which weighs 8.8lbs and the CM one
i wanna know which one you guys are using and the input on it, im running nitrous this year, until next season when i put in my new setup
and input would greatly appreciated
thanks in advance
Old Apr 16, 2003 | 10:37 AM
nsxblueteg's Avatar
forza makes a really good flywheel and can be rebuildable after years of use
Old Apr 16, 2003 | 10:58 AM
Default Re: (nsxblueteg)
does forza have a website?
Old Apr 16, 2003 | 11:00 AM
nsxblueteg's Avatar
Im not sure but go to AEIPERFOMAMCE.com and ask rob he is a distributor for them
Old Apr 16, 2003 | 11:07 AM
do you mean fidanza? on the site they carry fidanza flywheels
Old Apr 17, 2003 | 04:18 PM
Default Re: (hybridnorth)
i found out that the cm and fidanza flywheels have the replaceable surface, and for price their about the same, im gonna use a cm clutch so might aswell use the cm flywheel
Old Apr 17, 2003 | 04:59 PM
nsxblueteg's Avatar
ya I meant fidanza Sorry about that I just had my wisdom teeth pulled so im pretty out of it
Old Apr 19, 2003 | 04:45 PM
ouch, shitty man, hope they gave you enough drugs to keep ya pain free
Old Apr 19, 2003 | 04:50 PM
joe_bocc's Avatar
From what I've heard, Fidanza makes the CM flywheel so in reality they are the same thing.
Why is it you want a flywheel with a replaceable friction surface?
Old Apr 19, 2003 | 04:55 PM
Default Re: (joe_bocc)
when i launch, i slip the clutch and it takes up the slack in the tranny, so the clutch is partly engaged, and it rides on the pressure plate and flywheel, and wears them out
dragonjay006
Nov 22, 2009 08:03 PM
H2B-EK4
Nov 10, 2009 10:15 AM
H2B-EK4
Oct 23, 2009 07:25 AM
See Are X
Jun 17, 2008 08:33 PM
