Help, I'm stumped...
Old Jun 26, 2001 | 08:54 PM
clockworks's Avatar
Default Help, I'm stumped...
For the past couple weeks the engine in my 88 Prelude Si has been acting strange. After the car is fully warmed up, the car intermittently (sp?) stumbles and has no throttle response. I have replaced the plugs, wires, coil (I have an MSD 6A and blaster 2 coil), cap/rotor, fuel filter, compression is good, crank/TDC sensors are within resistance specs, air/fuel gauge reads normal,and the spark plugs read normal.
I suspect it's the ignition module because of the occurance after the engine is hot, but has anyone ever had one go bad on a 3g? It's seems odd because it doesn't soak up as much heat because it's mounted on the shock tower, and I thought that if it did go bad, the car wouldn't run at all. Any other things to check?
TIA,
Greg
Old Jun 26, 2001 | 08:59 PM
raene's Avatar
Default Re: Help, I'm stumped... (clockworks)
Have you checked that your cam timing is bang-on? How about your ignition timing? Just somethin' to think about .
Old Jun 27, 2001 | 02:58 PM
clockworks's Avatar
Default Re: Help, I'm stumped... (raeneshadow)
yep, cam timing is right on, as is the ignition timing. That was my first thought. Someone said it may be a dirty EGR. Any other ideas?
Greg
Old Jun 27, 2001 | 10:47 PM
raene's Avatar
Even though your A/F ratio is reading normal, is it quite up to speed? A faulty O2 sensor will still read stoich, it'll just respond to changes more sluggishly, causing stumbling idle, bad gas mileage, poor throttle response...
P.S. Have you tested your PCV valve yet?
[Modified by raeneshadow, 11:47 PM 6/27/2001]
Old Jun 28, 2001 | 06:38 AM
clockworks's Avatar
yeah, the pcv is good. I have the A/F meter attached to the secondary O2 (on the 3g ludes, there are two on the manifold). I have a brand new O2 that I haven't gotten around to putting in. Is the O2 that big of a reference for the PGM-FI?
Thanks man,
Greg
Old Jun 28, 2001 | 03:03 PM
raene's Avatar
The O2 sensor is like THE main reference for electronic fuel injection . It controls idle air mixture and part-throttle air mixture, but it's completely irrelevant under WOT. So if it never stumbles or anything under WOT, you might have a solution .
Old Jun 28, 2001 | 05:38 PM
clockworks's Avatar
I think you're right on, as I got a check engine light today; secondary O2. I guess it's the O2 itself, I thought my A/F meter was altering the input signal because it's homemade and may draw more current than an autometer, but the O2 input to that is on a switch. O2 it is, and lucky for me I have a brand new one lying around.
Thanks bro,
Greg
Old Jun 28, 2001 | 06:08 PM
raene's Avatar
Funny how the ECU takes so long to notice the O2 signal is crappy, huh? Oh well, c'est la vie. Glad I could be of assistance .
AllMotor12s
Nov 11, 2007 04:20 PM
tour de france turbo
Sep 13, 2005 03:09 PM
Steve90HB
Apr 2, 2004 10:52 PM
skrewdlude
Nov 3, 2003 09:00 AM
clockworks
Jun 25, 2001 07:00 AM
