Fender well trimming
Old Apr 16, 2003 | 07:07 AM
sparknblaze's Avatar
Default Fender well trimming
OK. I just bought a dremmel (the smaller hand-held cordless) which has the ability to cut metal. I have had a problem with installing the ingalls camber kit because it kept hitting this little lip inside the inner fender. And it also required a bit of trimming inside the control arm.
My question is: Since I'm a rookie Is there anything I need to be wary of before trimming the inner fender?
Old Apr 16, 2003 | 08:20 AM
rick_spiff's Avatar
Default Re: Fender well trimming (sparknblaze)
1) Get fiber reinforced discs for your dremel. They will last long(enough)er.
2) WEAR EYE PROTECTION.
3) Get some super-zinc primer/sealant paint. Clean the very thoroughly once you are done and sure that you stuff will fit, then paint. We don't want any rust.
You just need to trim back a little of the lip, right? If you get into anything structural, that's more complicated.
FreshPurp
Paint and Body
Oct 4, 2013 05:11 PM
dgerej2
Nov 23, 2009 08:36 PM
farkiller
Aug 8, 2009 04:40 AM
Teawins21
Honda S2000
17
Mar 27, 2009 07:11 PM
No2Pencil
24
Jan 5, 2007 06:19 AM
