Transmission Question
Old Apr 16, 2003 | 04:22 AM
BlazingSIRT's Avatar
Default Transmission Question
I removed the gear housing cause it had a couple of small cracks on it around where it would bolt up to the clutch housing. I figured I would fix it now while it was out before it caused problems later. I took it to a shop and they did a little welding for me. After I got it back though, I wasn't able to get it to close. If I take out the shift forks everything lines up and seals. But with them in, I have just over a 1/2" gap. Does anyone know what might be causing this and how to fix it. BTW, the tranny is a 94 JDM H22A w/ factory LSD. Thanks.
Old Apr 16, 2003 | 05:23 AM
b19coupe's Avatar
Default Re: Transmission Question (BlazingSIRT)
This may be a silly question, but did you remove the detent ***** and springs?
Old Apr 16, 2003 | 03:19 PM
PupaScoopa's Avatar
Default Re: Transmission Question (b19coupe)
Yeah, I bet the springs are causing the shift forks to stop before they go in allt he way... though I don't remember where the notches are on the shift forks for those ***** (if they're near the tops or middle).
Old Apr 29, 2003 | 04:29 AM
Default Re: Transmission Question (PupaScoopa)
Yeah, I have both of them out and I still can't get it to close. I've taken it to a couple of shops and they've run into the same problems. At first I thought that it might be the snap rings but I can't get close enough for it to be. Any other ideas? Thanks.
Old Apr 29, 2003 | 04:34 AM
b19coupe's Avatar
Sounds like you may be having trouble getting the shift fork shafts to go into the holes in the case. Try shifting it into different gears, I have had a problem where the case would not go together in neutral, but in a certain gear (I don't remember which) the case slid together fairly easily. In neutral, the shafts tend to flop around a little, and don't want to line up.
[vodka]
May 21, 2011 08:29 PM
Demonis
Honda Civic (2006 - 2015)
Mar 24, 2007 09:37 AM
