tranny mount question: b18c into 93 si hatch
Old Apr 16, 2003 | 12:35 AM
xchosun1x's Avatar
Default tranny mount question: b18c into 93 si hatch
for B series swap, what tranny mounts do i need or can use for the swap?
i know there are two tranny mounts, top and rear, and i also know one of the stock mounts from the EG
can be used and the other not. Just dont remember which ones...
can you guys help me out?
thanks
Old Apr 16, 2003 | 04:35 AM
bikeboy80's Avatar
Default Re: tranny mount question: b18c into 93 si hatch (xchosun1x)
the two tranny mounts are front and top, the front you use the part that attatches to the tranny from the b series motor and the part that attatches to the frame from the civic. the top mount you need from the b series
do a search, i know thewre is a picture that is floating around that explains all of this
Old Apr 16, 2003 | 05:12 AM
afish47's Avatar
Default Re: tranny mount question: b18c into 93 si hatch (bikeboy80)
its not that great of a pic so i hope it helps
Old Apr 16, 2003 | 07:03 AM
AMG's Avatar
AMG
Default Re: tranny mount question: b18c into 93 si hatch (afish47)
Im pretty sure all you need are the civic mounts...........Its a straight drop in if i am not mistaken
Old Apr 16, 2003 | 07:20 AM
bikeboy80's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by afish47 &raquo;</TD></TR><TR><TD CLASS="quote">its not that great of a pic so i hope it helps
that was exactly the one i was talking about, i was just too lazy to search for it
you do need some of the integra mounts, period.
i used all integra mounts and just cut some metal off the two lower front mounts to make them work
Old Apr 16, 2003 | 09:36 AM
AMG's Avatar
AMG
whoops.......I meant to say "All you need are the teg mounts.......whoops sorry about that. Some say if you use just the teg mounts, the motor sits higher and can rub against the hood, but my friends gsr'd hatch just has the teg mounts, so whatever floats your boat I guess
Old Apr 16, 2003 | 05:22 PM
xchosun1x's Avatar
Default Re: tranny mount question: b18c into 93 si hatch (Si-G93)
thanks alot guys for you help....
i'm sure i'll get this thing to work with that little diagram
i'll tell you how things come out...
Turbo O
Aug 17, 2007 03:34 PM
crazyguy
Jun 11, 2007 11:38 AM
caymanjdm97dc2
Dec 29, 2006 12:39 PM
phantom_sol
Feb 24, 2004 09:45 AM
pwrofdrm
Dec 28, 2003 03:17 PM
