info on Motul 600 racing brake fluid
Old Apr 15, 2003 | 11:52 PM
austrian type-R's Avatar
Default info on Motul 600 racing brake fluid
Since I did a search and googled a bit around I found following info about the 600 brake fluid.
Not usebale for street, has to be changed every 2nd race or all 4 weeks.
WTF?!
Old Apr 16, 2003 | 05:38 AM
Cosworth's Avatar
Default Re: info on Motul 600 racing brake fluid (austrian type-R)
Mutul 600 is very hydroscopic, unlike ATE superblue.
It's not really that bad... a friend of mine (pyromasteR) changes it out every 3 months.
edit - that's 3 months of street driving.
Old Apr 16, 2003 | 05:40 AM
Back in Black's Avatar
Rather OG
Default Re: info on Motul 600 racing brake fluid (Cosworth)
I love it.
Jason-
a former Superblue user
Old Apr 16, 2003 | 06:03 AM
Backmarker's Avatar
Default Re: info on Motul 600 racing brake fluid (Jason Franza)
I am also a former ATE user who has switched to Motul 600. I change it every couple of months. Definitely boils less than ATE - although it did seem to give a slightly softer pedal feel. Could be just in my head, though.
Old Apr 16, 2003 | 06:29 AM
Warren's Avatar
Wrong-Way Wang
Softer pedal in general, but it's hard to boil. I used to run it on the street all the time in my S4. Bled it once every 6 months.
Sheeeit. I haven't bled the brakes since last August on my race car. It's running Motul. Ask any of my passengers if my brakes weren't working well at the Expo.
Warren
Old Apr 16, 2003 | 06:37 AM
PiYoImuT's Avatar
Default Re: info on Motul 600 racing brake fluid (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Well.... So you <u>do</u> use the brakes? At least occasionally?
Bwahahaha.... :D
Old Apr 16, 2003 | 07:19 AM
uncleben's Avatar
every 4 weeks? oops.
no problems here either though...
Old Apr 16, 2003 | 07:23 AM
BDiddy's Avatar
Default Re: info on Motul 600 racing brake fluid (uncleben)
i didnt feel any brake fade in my car and I had just changed it. I like it.
Old Apr 16, 2003 | 07:28 AM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">Not usebale for street, has to be changed every 2nd race or all 4 weeks.
WTF?!</TD></TR></TABLE>
Waste of money. IMO.
Just get ATE racing and flush after every driving event or every year on the street.
Old Apr 16, 2003 | 07:29 AM
.RJ's Avatar
.RJ
Default Re: info on Motul 600 racing brake fluid (Warren)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren &raquo;</TD></TR><TR><TD CLASS="quote">Softer pedal in general</TD></TR></TABLE>
I thought all of this was a load of horseshit
Old Apr 16, 2003 | 07:34 AM
Warren's Avatar
Wrong-Way Wang
Default Re: info on Motul 600 racing brake fluid (.RJ)
It's always been softer when I change to Motul. It's just slightly more compressable than other brake fluids. Beats me. Before this, I thought fluids were basically uncompressable. I guess 1000 psi of line pressure changes that a bit.
Warren
Old Apr 16, 2003 | 08:35 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">Not usebale for street, has to be changed every 2nd race or all 4 weeks.</TD></TR></TABLE>
That's not true. Not true at all. Motul RBF 600 doesn't accumulate moisture any faster than any other brake fluid (except Castrol SRF, which costs five times as much).
I've gotten great results from Motul - I flush it in spring and it's good for the entire season (8 months, 8-10 track events).
Motul has higher boiling temperatures, both dry and wet, than ATE. However, Cobalt Friction has fluid whose boiling temperatures are even higher. And both fluids (Motul and Cobalt) are reasonably priced. I'm happy to spend a few bucks for the best protection against boilover.
Here are the dry and wet boiling points for many of the most popular brake fluids:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3 MINIMUM
DRY:446F -- WET:311F --- DOT4 MINIMUM
DRY:500F -- WET:356F --- DOT5 MINIMUM
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
DRY:620F -- WET:425F --- COBALT SUPER XRF
ARRANGED BY WET BOILING POINT:
NipTucked
18
Apr 20, 2009 09:48 AM
nsxtasy
21
Apr 9, 2008 08:36 AM
slow91crx
12
May 17, 2005 05:38 PM
motore
Oct 14, 2003 03:25 PM
onyx00
Jun 23, 2003 11:38 AM
