need help with greddy turbo kit on zc crx and some suggestions
Old Apr 15, 2003 | 11:11 PM
hybridtech's Avatar
Default need help with greddy turbo kit on zc crx and some suggestions
I got that 92-95 civic turbo kit from greddy. I need help wiring in the fmu to the ecu. I kept the stock ecu PM6. I just bought the car a couple of months ago, I have not had a chance the get a helms for it.
INJ1=?
INJ2=?
INJ3=?
INJ4=?
ICM (RPM)=?
PG (INJ G)=?
LG (G)=?
IGP (12V)=?
MAP=?
Can you guys answer the question marks with wire color and what ecu harness? Thanks, also any suggestions on what I need to safely run 8psi. I went out and got a boost gauge, oil pressure gauge (which doesnt fit its 60mm instead of 52mm) and a type s bov.
O and how do you post pictures?
thanks
Old Apr 16, 2003 | 05:40 AM
drjondurst's Avatar
Default Re: need help with greddy turbo kit on zc crx and some suggestions (hybridtech)
Basically the only thing I can help u out with out of all that is how to post pics. Heres the code..
[im] put pic URL here [/im] Where I put "im".. put "img" instead and it'll work.
Old Apr 16, 2003 | 08:01 AM
hybridtech's Avatar
Default Re: need help with greddy turbo kit on zc crx and some suggestions (drjondurst)
Thanks can anybody help me with the wiring? Do I also need to add check valves? Here is a picture of the instructions from GReddy.
[img]C:\Documents and Settings/Andy/Desktop/downloaded stuff/wirediagram2turbokit.jpg.jpg[/img]
Old Apr 16, 2003 | 08:03 AM
hybridtech's Avatar
The picture is for a 92-95 civic EX/SI. Is it the same for am '89 cix si ecu?
Old Apr 16, 2003 | 09:36 AM
slowpokesi's Avatar
#1 injector A1
#2 injector A3
#3 injector A5
#4 injector A7
IGN power 1 for ECU A13
IGN power 2 for ECU A15
Power ground 1 for ECU A2
Power Ground 2 for ECU A4
Logic Ground 1 for ECU A16
Logic ground 2 for ECU A18
EVAP Purge control solenoid valve A6
Fuel tank pressure sensor -
VTEC solenoid -
Fuel pressure solenoid vlave -
Fuel pump relay A12
Fuel pump relay A14
Malfunction indicator lamp B6
Ignition control module B15
Ignition control module B17
IACV (EACV) A11
Primary O2 signal C16
Radiator fan control B4
Tandem valve control solenoid B2
CKP P C1
CKP G C1
TDC P C3
TDC G C4
A/C clutch relay B3
Starter switch signal B13
Service check signal (Ignition timing adjusting connector) B20
Backup voltage B1
Brake switch signal C10
Alternator signal B14
Alternator control B5
ECT C6
ELD B19
IAT C5
PA C9
TPS C7
VSS B16
Sensor voltage C13
Sensor ground C12
MAP C11
Map sensor voltage C15
MAP sensor ground C14
here is a pin chart along with colors
though the colors may not be exact.
ozziehonda
Feb 16, 2008 08:59 AM
EFb18b
Sep 17, 2003 04:16 AM
sohcvtec1995
Sep 11, 2003 10:53 AM
etmoron
Aug 11, 2003 03:54 PM
etmoron
Aug 6, 2003 01:40 PM
