Turbo Timer HELP!!!!!!
Old Sep 10, 2003 | 02:07 PM
sohcvtec1995's Avatar
Default Turbo Timer HELP!!!!!!
I have a greddy TT. I searched and got some pics and some diagrams, and i hooked mine up exactly like in the pic but nothing. It turns on and every thing but when i turn the car off the TT turns off also. Anyone know exactly what wires go to what color? I dont have the harness, nor do i have the grey purple or brown wire hooked up since everyone says you dont need to.
Old Sep 10, 2003 | 02:31 PM
Default Re: Turbo Timer HELP!!!!!! (sohcvtec1995)
Anyone?
Old Sep 10, 2003 | 05:44 PM
SEVENSIX's Avatar
hey, are you running a homemade turbo setup? or is it the Greddy Kit???
Just wondering cause I may be getting the Greddy kit and putting it on my 95ex..
Good luck with your TT.
-Dgalas
Old Sep 10, 2003 | 06:10 PM
VisualAutoMotoring's Avatar
Default Re: Turbo Timer HELP!!!!!! (SEVENSIX)
ummm...
you might have the ignition and constant 12v reversed...plus you will have to hook up the brown to your e-brake for sure
Old Sep 10, 2003 | 06:40 PM
Default Re: Turbo Timer HELP!!!!!! (PRojectSi2)
well guesing from your sig. you have a 92-95 Civic....hope this helps....
take the GReddy harness Red wire --- hook it up to the WHITE on your ignition harness
GReddy harness blue --- yellow on your ignition harness
GReddy harness green --- black w/yellow on your ignition harness
GReddy harness brown --- tap into your e-brake wire should only be one wire
Old Sep 11, 2003 | 10:53 AM
thanks all. I have a home made turbo that is going to be put in soon. I am just doing all off the electronics first.
dust559
Nov 18, 2015 09:40 PM
JDM_WHR
May 19, 2010 06:47 PM
jdm91CrxSi
Feb 25, 2009 05:39 PM
ex_on_lsd
Oct 20, 2007 06:20 PM
