Need some info about piston swap in d16z6
Old Apr 15, 2003 | 09:45 PM
variable's Avatar
Default Need some info about piston swap in d16z6
I want to raise the compression in my d16z6-i've heard that JDM ZC psitons are a direct swap, i've heard that 86-88 USDM Integra pistons are a direct swap, and i've heard that neither option is a direct swap and modification is required to make it work. What is the deal? What should i get? What gains should i expect?
I have a 95 EX coupe with stock internals, STR Comp fuel rail, and 95 GSR OEM intake, FYI. This seems like a cost effective power gainer if its true
Old Apr 15, 2003 | 09:57 PM
madhatch's Avatar
Default Re: Need some info about piston swap in d16z6 (variable)
d16 a1, old skuul teggie pistons work, I think the zc ones will. Find the d series buildup and look in there. Or contact mistbone or spade
Old Apr 15, 2003 | 11:53 PM
Mr. Thunderlips's Avatar
Peep dis' yo...
https://honda-tech.com/zerothread?id=457659
90 DX Driver
Apr 4, 2009 11:31 AM
socialistic
Sep 20, 2008 10:30 AM
dud1y3d
11
Oct 31, 2004 04:36 PM
Corporation
16
Aug 20, 2004 11:19 PM
BoostFrenzy.com
Nov 19, 2003 02:34 PM
