Ls/vtec question? S1 tranny question?
I know that its' the b16a head but what do you need from the ls, the bottom end obviously but whats this including?? and how much quicker is this then the b16a, both stock??
How much would an s1 tranny cost(with limited slip) and would it be worth it? Is the s1 tranny hydro?? i am quessing no but not sure thanks
chris
chris
Well what do you mean by "stock if you put a b16 head on a LS then it's not stock. I would run a b16 tranny if I were you the LS has longer gears. If you put B16 pistons in your LS block plus the B16 head You will Be faster than a type R
grip200kg
Dec 9, 2008 12:31 PM
cherryB-16a
Mar 29, 2007 06:57 PM
Ratchback
Dec 23, 2005 07:42 AM
