How do I adjust Timing on an Unorthodox racing crank pulley?
Old Apr 15, 2003 | 06:35 PM
wantmorepower's Avatar
New User
Default How do I adjust Timing on an Unorthodox racing crank pulley?
Does anyone know how to adjust timing on a Unorthodox racing crank race pulley (B18c5)? There is only one mark on it. Thanks
(I wish I can trade it for an http://www.inlinefour.com/infourn1encr.html pulley)
Old Apr 15, 2003 | 08:08 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (wantmorepower)
Well I'm not 100% sure on this, since I've never actually used a timing light before, but I think if you get an inductive timing light w/ the advance **** on it, you would then use the light to line up the TDC mark. You set the **** to whatever timing you want (16 or 18 BTDC) and then line up the TDC mark.
If you have a timing light w/o advance, you have to rely on the 3 timing marks like on the stock pulley.
So you need a timing light with advance. Someone please tell me if I'm wrong.
Old Apr 15, 2003 | 08:12 PM
New User
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (PatrickGSR94)
i do have the timing light with advance --I need more info
Old Apr 15, 2003 | 08:31 PM
SiR-DC2's Avatar
even a timing light w/ advance can be out if your cam timing has changed sligtly, if you regularly check timing then you should be familiar w/ how the dist. turns in relation to the advance or retard
Old Apr 16, 2003 | 05:49 AM
JimBlake's Avatar
The only mark should be at TDC, but you can verify this by checking against the mark on the crankshaft timing sprocket.
So set your timing light for 16 degrees advance & shine it on the mark. If you had a light without the advance feature, you could measure 16deg & make a mark with a sharpie pen or something...
Old Apr 16, 2003 | 09:52 PM
New User
Default Re: How do I adjust Timing on an Unorthodox racing crank pulley? (JimBlake)
thanks a lot Jim
at 16 deg advan the cam sprokets line up
JDMtype Eg6
Sep 3, 2008 05:14 AM
LoseRPunKx182
Aug 6, 2005 09:36 PM
IggDawg
Mar 13, 2004 03:27 PM
david90
Nov 18, 2003 10:09 AM
boosting
Nov 14, 2002 08:44 PM
