why would my blinkers blink "ricer style"? (Twice as fast...even though all the bulbs work fine)!
Old Apr 15, 2003 | 05:37 PM
Turtle's Avatar
Default why would my blinkers blink "ricer style"? (Twice as fast...even though all the bulbs work fine)!
I dont get it...fuses are all ok...bulbs are all stock...working well...
Any suggestions? I'm emarassed to use my turn signals, and I'm sure people think I'm an *** on the highway!
Old Apr 15, 2003 | 05:39 PM
yoshi234's Avatar
I shoot brides
Default Re: why would my blinkers blink "ricer style"? (Twice as fast...even though all the bulbs work fine)
j00 check both bulbs in the corner lens? (i think there are two there)
yshi - whose EE blinx like a stunna
Old Apr 15, 2003 | 05:43 PM
Turtle's Avatar
Default Re: why would my blinkers blink "ricer style"? (yoshi234)
nope fine....is there a relay that could be bad? If so, where at? Can i test to see if it works?
Old Apr 15, 2003 | 05:49 PM
Cosworth's Avatar
Default Re: why would my blinkers blink "ricer style"? (Turtle)
Did you triple check all your lights?
I had the super blinkers on the way back from Expo, since I busted the right turn signal bulb. When I put the correct one, it's working fine.
Also, check to see if your brake light bulb(which has two filaments: one for parking light & one for brake light) hasn't had its filaments melt into one filament. (some times one of them brake & latches into the other filament & cause a short).
Old Apr 15, 2003 | 05:52 PM
GSRrR's Avatar
i am not sure if the 98+ tegs are wired like 94-97 but check the corners again.
when you turn on the blinker, does the corner light get brighter? if it does not, then change that bulb. HTH
Old Apr 15, 2003 | 05:53 PM
Turtle's Avatar
Default Re: why would my blinkers blink "ricer style"? (Cosworth)
times. Actually I think that my instructor would have noticed if it was a brake lights. And I just checked my lights again and all worky.
EDIT: GOT IT TO WORK...weird problem though...here is the fix...
There is three grooves on the main turn signal bulb. Two of them guide the bulb to the two contacts located at the base of the connector. The other (third) groove has a copper connector that actually has to make contact with the metal at the base of the bulb. This was damaged when I tried the euro Phillips bulbs from Trevor (Visual Dynamics). So when I bent those back, (so that the would make contact) viola! All works good....
I am so happy, because its a pesky annoying problem....no more!
B
Modified by Turtle at 10:19 PM 4/15/2003
Old Apr 15, 2003 | 06:14 PM
HiRevn's Avatar
there should be a flasher relay. You may want to check that if all the bulbs are ok.
Old Apr 15, 2003 | 06:20 PM
DsITR's Avatar
Default Re: why would my blinkers blink "ricer style"? (HiRevn)
ricer gremlins...
Old Apr 15, 2003 | 06:22 PM
PiYoImuT's Avatar
You may want to keep the hyper blinker..
makes ur car 'look' faster.. LoL
professorman
Oct 27, 2013 06:28 AM
nighthawkgsr
15
Oct 12, 2007 10:16 PM
mackoy20
Dec 17, 2006 06:01 AM
slammedef06
Jan 3, 2006 12:40 PM
