1st Gear VTEC not engaging???
Old Apr 15, 2003 | 05:23 PM
user 996328629's Avatar
Default 1st Gear VTEC not engaging???
Alright guys, i noticed my car was cutting out sometiems when i floored it threw any gear, the power would just cut out and than go back in.
So I got a new cap and rotor, and put them in, and when i took the old one out, the sqrew that holds rotor in place, was just chillin at the bottem of the dist. cap. And the Cover that covers the internals of the dist. was ruined. I took that out, and didnt replace it(i will soon). A whole prong inside the cap was bent off, and the rotor was horrable condition, i dont know how my car still ran with power.
ANYWAY, i replaced it all, and took it out, and started rippin on it, the car was amazing, ive never felt the change over rip this much. But that all ended today, for some reason, my VTEC in 1st gear doesnt change over? I havnt taken it to 8k without VTEC, because there was no power, i wasnt even going to attempt, but i ripped it to about 7k, and still no VTEC.
Could my problem be that distributor cover?????? OR what could it be!?!?!
2nd and 3rd gear vtec pull hard as anything...
Im so confused..
HELP!
Old Apr 15, 2003 | 06:16 PM
P1mpSlap's Avatar
Default Re: 1st Gear VTEC not engaging??? (Swags04)
It's prolly all just in your head. Make sure everything is correct with your installation and let the car warm up. Check your oil level to see if it's all good.
Do not even think about taking your car into VTEC unless the car has warmed up.
It'll engage in 1st gear, but the MAP sensor has to send the correct signal and the ECU also has to read the correct oil pressure level along with all RPM signal.
If those aren't correct VTEC wont switch over.
Old Apr 15, 2003 | 06:43 PM
Default Re: 1st Gear VTEC not engaging??? (P1mpSlap)
Well it was definitly warmed up, and ill check if the oils right, but i dont hear or FEEL the VTEC kick in like it did yesterday...
Old Apr 16, 2003 | 01:37 PM
b16a1sirhb's Avatar
The same thing happened to me once too. It was the vss, with a stock computer, your vtec will not turn on unless your going over like 20 mph or something along the lines of that, check your speedometer next time. Just a thought.
Old Apr 16, 2003 | 02:22 PM
My VTEC is set at stock. I have no VAFC, what is 4400's mph? anyone know?
Old Apr 16, 2003 | 09:33 PM
X2BOARD's Avatar
Well, as mentioned...you must be going at least 20mph for vtec to engage... and the VSS plays and important role in this... but I'd first check your oil LEVEL... vtec does depend on oil PRESSURE, but if your oil level is too low or high, it will affect engagement.
X2
Old Apr 16, 2003 | 09:50 PM
romeo619romeo's Avatar
Default Re: 1st Gear VTEC not engaging??? (X2BOARD)
i usually dont feel the cross over on first gear but in 2nd i can
Old Apr 17, 2003 | 01:50 AM
MikeSarr_GSR's Avatar
Default Re: 1st Gear VTEC not engaging??? (romeo619romeo)
the load on the motor is different in each gear. thats why
Old Apr 17, 2003 | 07:35 AM
X2BOARD's Avatar
Default Re: 1st Gear VTEC not engaging??? (MikeSarr_GSR)
I can feel the x-o in everygear.... I mean... it's not a sohc...hahaha...
X2
Old Apr 17, 2003 | 09:11 AM
B2FiNiTY's Avatar
Check your oil.
Old Apr 18, 2003 | 11:00 AM
pope's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">I can feel the x-o in everygear.... I mean... it's not a sohc...hahaha...
X2</TD></TR></TABLE>
lol sohc vtec sounds so inferior...
Old Apr 18, 2003 | 09:06 PM
X2BOARD's Avatar
Default Re: 1st Gear VTEC not engaging??? (pope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pope &raquo;</TD></TR><TR><TD CLASS="quote">
lol sohc vtec sounds so inferior...</TD></TR></TABLE>
EASY brutha... I still have a sohc vtec daily driver...
X2
taakuumii!!
29
Aug 17, 2018 10:14 PM
Lightsped
26
Jan 8, 2009 02:09 PM
racingfan
Apr 28, 2005 03:17 AM
an2ny888
Mar 1, 2004 01:04 PM
