knocking or ticking noise from B16..... =(
Old Apr 15, 2003 | 04:03 PM
EL Vap133's Avatar
Default knocking or ticking noise from B16..... =(
So there was this knocking/loud ticing noise coming from my B16 motor. It's a 1st gen B16 in my 88 CRX. The first day it made that noise and then it went away when the car was warmed up. The next day the noise wouldn't go away. The day after, the noise was still there and everytime I decelerated or just stepped on the brake, the idle would shoot down and the car would shut off. It must have turned off like 15 times that day.
So my question is, what do you guys think it is? A friend of mine said it sounded like the lifters, another thinks it's the rods. The head is now off, there is no play on the pistons when it is turned manually. The lifters feel ok, what else can it be? Before the head was off, the car still ran. Help me guys, thanks.
Old Apr 15, 2003 | 04:31 PM
Redline130's Avatar
Default Re: knocking or ticking noise from B16..... =( (Vap133)
Valves needing adjustment maybe?
Old Apr 15, 2003 | 04:33 PM
Buzz Kill's Avatar
Default Re: knocking or ticking noise from B16..... =( (Redline130)
An exhaust leak will sometimes make a ticking noise.
Old Apr 15, 2003 | 04:36 PM
EL Vap133's Avatar
Default Re: knocking or ticking noise from B16..... =( (Buzz Kill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Valves needing adjustment maybe?</TD></TR></TABLE> Nah, it was too loud to be the valves needing adjusting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzz Kill &raquo;</TD></TR><TR><TD CLASS="quote">An exhaust leak will sometimes make a ticking noise.</TD></TR></TABLE>
Really? It was like a "tack tack tack", like 3 per second but how would an exhaust leak cause that? Thanks for your replies though...
Old Apr 15, 2003 | 04:54 PM
bryant's Avatar
somtimes injectors make clicking noises. but probley not that loud. I would get a valve adjustment anyway. its $40 and cant hurt anything. I also had the same problem and took it to honda to find out what was going on. They told me the cam gear bolt ( bolt the holds the cam grear on) the cam was loose and just wobbleing around making the big tikking, clanking sound under the hood. try and put your ear to your motor and see kinda where is comming from.
Old Apr 15, 2003 | 05:03 PM
EL Vap133's Avatar
Default Re: knocking or ticking noise from B16..... =( (Bryant)
Well my mechanic was the one that suggested that it was the lifters, that's why I asked. I don't know what to do now. The lifters are like $25 at Honda, so for all 8 it will be $200....
Old Apr 15, 2003 | 05:39 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/zerothread?id=157546
Old Apr 15, 2003 | 05:50 PM
EL Vap133's Avatar
Default Re: knocking or ticking noise from B16..... =( (88DXCRX)
Thanks again for your help!
88CRXJ
May 28, 2015 11:44 AM
R91Si
15
Jan 15, 2004 01:19 PM
abadb16
May 6, 2003 09:26 PM
