D-series and ZC stuff for Sale
D16A1 Head (with valves).....$50
D16A1 Cams......$30
D16 Transmission......$150
D16A1 Dist. Cap and coil (convert to external coil, MSD cap, accel coil) never used still in box...$75
D16A1 pistons (75mm bore, set of 7)......$120
D16A1 headgasket (Fel-Pro)......$35 never used
D16A1 piston rings (chromoly)....$85 never used
D16A1 intake manifold and throttle body.....$40
D16A1 intake manifold and throttle body (bored to 62mm).....$80
D16A1 alternator.......$80
D16A1 starter.......$70
D16A1 distributor.......$175 4 mnths old
ZC engine block and crankshaft.......$100
ZC pistons.....(set of 4)...$150
ZC head with valves.....$100
ZC cams.....$90
D-series Turbo Kit.......$400 **SOLD**
14B turbo, Sidemount IC, HF manifold, adapterplate, wastegate, FMU, fuel pump, boost gage, a-pillar mount.
parts are located in blacksburg, VA if you would like to meet up. zip code is 24060 if you want to check on shipping.
Modified by integen1 at 6:50 AM 4/16/2003
D16A1 Cams......$30
ZC cams.....$90
h22_crx
Aug 23, 2005 09:46 PM
*Boostwerks*
Dec 18, 2003 11:50 AM
