Removing ball joint in A arm
Old Jun 26, 2001 | 02:06 PM
KK's Avatar
KK
Default Removing ball joint in A arm
What's the best way to remove the ball joint in the upper A arm on the R? Should I purchase a ball joint separator or is there a better way? I need to remove it to install a KMAC camber kit.
Thanks,
Mark
Old Jun 26, 2001 | 02:27 PM
356racing's Avatar
Default Re: Removing ball joint in A arm (KK)
<--- EDIT---> Bad reading on my part. You need a press, off to the local machine shop you go.
[Modified by 356racing, 3:29 PM 6/26/2001]
Old Jun 26, 2001 | 02:30 PM
Warren's Avatar
Wrong-Way Wang
Default Re: Removing ball joint in A arm (356racing)
Heh, well I suppose if the arm is coming off anyways
See if you can borrow one from Trak Auto.
Warren
russianswty
Feb 18, 2007 02:24 PM
accordfreak
Jul 11, 2003 03:04 PM
Flamenco-T
Aug 21, 2002 11:49 PM
brody
Oct 10, 2001 01:15 AM
