Thowin code 83 or 73 cant tell.
Old Apr 15, 2003 | 10:56 AM
Neptune's Avatar
Default Thowin code 83 or 73 cant tell.
Okay so I counted the long blinks, but when should I start counting, cause when you turnt he key, the cel goes off for a few seconds, then it comes back on, does that start the count at one or do I start count at the next one? If you read my other post, my cluitch felt like it was slipping and the idle was all funny, but the code 73 is misfire on cylinder 3 so could that be the prob. There is no code 83
Old Apr 15, 2003 | 10:58 AM
Spade's Avatar
Default Re: Thowin code 83 or 73 cant tell. (Neptune)
Yes, it will go off then start the count once it comes on.
http://www.hondata.com/techecucodes.html
Old Apr 15, 2003 | 10:59 AM
Neptune's Avatar
Default Re: Thowin code 83 or 73 cant tell. (Spade)
Thanks spade, just figured out, a spark plug wire wasnt connected at the opposite end, not the connection on the valve cover but the other side, crossing my fingers this is the problem.
Old Apr 15, 2003 | 11:04 AM
Neptune's Avatar
So I just pluged that back in drove the car, but the cel is still on. Do I need to reset my ecu or anyhting?
Says I am throwin a code one now. Which is intake air temperature sensor. Any ideas?
luckystryx
Aug 29, 2018 06:15 PM
suprant0010
Apr 19, 2014 02:41 AM
rudyndrew
13
Feb 24, 2011 07:00 AM
A92civicxJDMb16a
Oct 13, 2003 02:29 PM
White Lightnin
Jun 28, 2002 09:15 AM
