power to manual steering
Old Apr 15, 2003 | 09:57 AM
marques4130's Avatar
Default power to manual steering
i just got finished swapping in a manual rack into my 93 civic ex coupe. i looked all aroundhere and alot of people said to buy the subframe along with the manual rack becuz the bolt pattern was a little different on the passenger side mounting bracket. (about .25") i had the yard i got it from put the rack on a power steering model and they said it bolted up fine. once i had got my new rack in i realized the difference. the power steering housing is bigger hence the longer bolt pattern. but you dont need to go and buy the subframe. instead just put the stock ps bushing over the bushing on the manual rack and bolt that sucker on with the ps bracket. i've had it on a few days now and it feels just fine. so dont waste money gettin the subframe.
Old Apr 15, 2003 | 10:34 AM
RyanEJ8's Avatar
Default Re: power to manual steering (marques4130)
what about looping the power steering rack instead of buying a manual one? what are the disadvantages to this? i want to remove my power steering.
Old Apr 15, 2003 | 10:50 AM
Default Re: power to manual steering (RyanCivic2000)
that would probably be the simplest way. i would've done that if i had known but i had been runnin my rack dry for a long time and i had ripped out all the lines. do that instead for sure. much easier and plus the power steering rack has a noticeably shorter ratio (quicker turning). i'm gettin used to my manual rack though. but yeah just loop the lines and consider making a breather for it. thats what the realtime integras do
Old Apr 15, 2003 | 11:00 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Could you please IM me or let me know here how to loop the PS system so I don't burn my PS rack out?
Old Apr 15, 2003 | 11:01 AM
RyanEJ8's Avatar
good. no change in plans then. this is what i planned on doing, just never have the time to take it out.
Old Apr 15, 2003 | 11:02 AM
RyanEJ8's Avatar
Default Re: power to manual steering (Apex i ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR &raquo;</TD></TR><TR><TD CLASS="quote">Could you please IM me or let me know here how to loop the PS system so I don't burn my PS rack out?</TD></TR></TABLE>
why not just post it here? it would be good info to have in the archives.
Old Apr 15, 2003 | 11:14 AM
ej8's Avatar
ej8
You can put a vented loop on your p/s rack
Old Apr 15, 2003 | 11:27 AM
Apex i ITR's Avatar
Default Re: power to manual steering (ej8)
A vented loop is all I need to not burn it up. Anymore descriptions beyond that. I'm having a hard time visualizing it......and to tell you the truth I'm having a hard time focusing on anything right now because I'm just ready to go home.
Old Apr 15, 2003 | 11:30 AM
try this, i found it in the archived content
<A HREF="https://honda-tech.com/zerothread?id=184202
" TARGET="_blank">https://honda-tech.com/zerothread?id=184202
</A>
Old Apr 15, 2003 | 11:36 AM
Apex i ITR's Avatar
Thanks.
Old Apr 15, 2003 | 11:38 AM
elwood's Avatar
I put the P.S. subframe on my car and my
left side shakes when I turn left.
Old Apr 15, 2003 | 08:29 PM
NonovUrbizniz's Avatar
Loved
Default Re: power to manual steering (d15dude)
correct me if I'm wrong but doesn't the stock non-power rack only bolt with the driver side mounts... I think the pass. side mount with the bushing is only used on the power steering rack...
At least that's what ES instructions for the bushings said.
Old Apr 16, 2003 | 09:17 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marques4130 &raquo;</TD></TR><TR><TD CLASS="quote">try this, i found it in the archived content
Very useful. Thanks.
Old Apr 16, 2003 | 09:30 AM
ej1civic's Avatar
wasn't the manual rack much easier to turn than the looped power rack?
Old Apr 16, 2003 | 04:39 PM
Default Re: power to manual steering (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I'm wrong but doesn't the stock non-power rack only bolt with the driver side mounts... I think the pass. side mount with the bushing is only used on the power steering rack...
At least that's what ES instructions for the bushings said.</TD></TR></TABLE>
look up at the first post in this forum, you can shove the ps bushing and bracket over the bushing on the manual rack and bolt it on, its working so far
Old Apr 16, 2003 | 05:56 PM
Loved
look up at the first post in this forum, you can shove the ps bushing and bracket over the bushing on the manual rack and bolt it on, its working so far</TD></TR></TABLE>
No what I'm saying/asking is that the non-power rack doesn't need those mounting points... the energy susp. master kit indicated that those mounts were not used on the non-powersteering model cars.
I'm sure it's better to use them if you can but I think stock they aren't there.
Old Apr 16, 2003 | 06:17 PM
bikeboy80's Avatar
on the manual subframe, the passenger side mount is "flat" the power one is curved, to compensate for the larger diameter rack. that is the ONLY difference i have personally looked at the subframes side by side
i agree that switching to a manual rack is good for a street driven car, i tried looping my power for awhile and the rack developed alot of excess play in it, it was very dangerous and unprrdictable at higher speeds. i loved the shorted ratio of the ps rack, but it was not worth having the play in it.
Old Apr 17, 2003 | 03:04 PM
I'm sure it's better to use them if you can but I think stock they aren't there.</TD></TR></TABLE>
i actually used the energy suspension bushing from my es kit to shove over the stock manual rack bushing. the manual rack does bolt on on the pass. side cuz mine came with the bracket. the reason es only makes one for the power model is that the stock power one has a cut in it to pull it off while the manual one has a bushing permanently attached
Old Apr 17, 2003 | 03:17 PM
AMG's Avatar
AMG
My JDM B18C is going into my 93 eh hatch this weekend. My question is I just took off the ps off my B18C because i didnt want it. Will it drive the same as my hatch that currently doesnt have ps or is there three types of steerings? I dont mean to confuse you, but does my hatch that doesnt have ps have some sort of power to hepl me steer and will i lack that with just taking off everything from my b-series motor?
gotenz90640
Mar 19, 2016 03:57 PM
blackGSRcoupe94
Jul 25, 2010 07:53 PM
NOman0608
Jan 25, 2009 07:17 AM
BlackOnBlackTeggie
31
Feb 1, 2005 07:49 AM
aeolus
May 11, 2003 11:03 AM
