will this amp power these subs ????
Old Apr 15, 2003 | 09:19 AM
yoyoyo's Avatar
Default will this amp power these subs ????
AMP.
1 power acoustik fi2x-300
75 WATTS X 2 @ 4 OHMS RMS 90 WATTAS X 2 @ 2 OHMS RMS 180 WATTS MONO@ 4 OHMS RMS 300 WATTS MAX
subs
2, 12" clarion pro audio srm300
• Polylaminate Cone
• Signal 4-ohm Voice Coils
• Kapton Bobbin
• Rear Vented Pole Piece
• Butyl-Rubber Surround
• Inverted Dust Cap
• Strontium Magnet
• 500 Watts Music Peak Power
• Fs: 32.8 Hz / Qts: 0.41 /Vas: 64.9 litres
• Frequency Response: 27 - 1,500 Hz
• Efficiency: 89.2 dB/W/m
• 250 watts RMS POWER
Old Apr 15, 2003 | 10:08 AM
koco's Avatar
Default Re: will this amp power these subs ???? (yoyoyo)
That amp seems too weak for that setup. Don't think you'll be happy with it. You'll never get ghetto bass from it.
Old Apr 15, 2003 | 10:17 AM
t0p_sh0tta's Avatar
Default Re: will this amp power these subs ???? (koco)
You'll only be sending the subs 75w each.
Old Apr 15, 2003 | 10:20 AM
yoyoyo's Avatar
i also have a orion xtreme 600x4 old model from 97-98
i was wondering if that would power my infinity 6.5 references components
and the 2, 12" subs
also is it possible to bridge a 4ch amp in to a 2ch amp
thankx
Old Apr 15, 2003 | 10:28 AM
t0p_sh0tta's Avatar
No, you cannot combine amps. Only select amps are what they call "strappable", which combines the output of the two. They must be 2 of the same amp (same power, playing the same freq., etc...).
I'd need the specs on the Orion. Can you bridge the rear channels to a 2ohm load?
Old Apr 15, 2003 | 06:02 PM
yoyoyo's Avatar
Default Re: will this amp power these subs ???? (t0p_sh0tta)
so i wont be able to run 2 subs and a set of compoents with the 600x4 orion amp ????????
Old Apr 15, 2003 | 06:54 PM
koco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">No, you cannot combine amps. Only select amps are what they call "strappable", which combines the output of the two. They must be 2 of the same amp (same power, playing the same freq., etc...).
I'd need the specs on the Orion. Can you bridge the rear channels to a 2ohm load?</TD></TR></TABLE>
You can run the components from the front channels and subs from the rear channels. It's a 4 channel amp, no?
chinkyx90
Audio / Security / Video
Mar 14, 2009 05:35 PM
vtecguy01
Sep 17, 2006 05:10 PM
tca0bell
Feb 27, 2005 09:17 AM
Calavera
17
Jun 24, 2002 10:30 AM
xJ.SLOTHx
Feb 14, 2002 11:12 PM
